Proximity Notification System ( Noise Maker)
Discussion in 'Gen 3 Prius Main Forum' started by jaredy, Dec 15, 2013.
  1. jaredy
    jaredy Member
    162
    SoCal
    Will the sound be turned off when shift is at : P: (parking) ?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It is off when the car is not moving or going over ~15mph. So it is off not just in P, but even when stopped in D.
    jaredy likes this.
  3. jaredy
    jaredy Member
    162
    SoCal
    Mark,
    Would you like to help check if the noise is made when you turn on your headlights in P.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It only makes the noise once the vehicle begins moving, the lights do not impact it.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Also the noisemaker works in "R" as well as "D" and "B" (and probably "N"). But again, only if you are moving, and its' operation has no connection with the lights, horn, or most other systems on the car. ;)
    I know it works in "R" because - backing out of my back yard after loading up my telescope I back up past the neighbors garage, where they were working. I look over to see both, jaw dropped staring at Pearl S. As I go by I say "I believe it's about to hover". :)
  6. jaredy
    jaredy Member
    162
    SoCal
    show a diagram.
  7. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Interesting. I'm wandering if this circuit could be tapped into for "parking proximity" sensors? I have been thinking about adding them for some time. However, I have been concerned about the reported false alarms which require people to manually turn them on or off. While it would be better if the speed was set to under 5 MPH or so, this may be a good compromise.
  8. jaredy
    jaredy Member
    162
    SoCal
    Speed Signal is ranged 10-16V.
