Parking my Prius C for 1+ months
Discussion in 'Prius c Main Forum' started by xzzz, Dec 13, 2013.
  1. xzzz
    xzzz Junior Member
    Phoenix, Arizona
    I'll be going on vacation for 1+ month and leaving my Prius C parked outside for around 30-40 days. Is there any special precautions I should take to make sure that my Prius will start successfully when I get back?
  2. Flying White Dutchman
    4,376
    313
    first check your manual about long time storage
    second unplug your 12volt battery is one
  3. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    For 30-40 days you really don't need to do anything special. Unless your 12V battery is nearing the end of its life, which it should not be yet.
  4. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    If it is going to be outside, I would use a sunshade and other things to protect the interior from heat. The other thing would be to watch out for rodents
    ewaboy likes this.
