Groceries and the hatchback door
Discussion in 'Gen 2 Prius Main Forum' started by Three60guy, Feb 25, 2006.
  1. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    Ok, around here we still have grocery stores which have kids load your groceries for you.
    So, wife and I are both in the Prius. We pull up the car and show the kid our number of the grocery cart and the kid tries to open the hatchback door. He can't. The car is still running of course. We have the keys. Mine is in my pocket and my wifes is in her purse.
    So, how the heck does one get the hatchback door open under these conditions? Should it open?
    I went out and it wouldn't open. Dang. I had to go back and push the power button. Then went back out and the hatchback door opened.
    Isn't there a better way? :) yes, flames are expected :) hehe
    (yes, I did a search....no, didn't find anything useful)
  2. aaf709
    3,862
    2022 Prius Prime
    Both fobs and you are in the car, right?
    Pressing the button that locks and unlocks all doors (on the driver's side) should unlock the hatchback as well (or am I missing the problem?).
    One thing I miss from my old car was the lever next to the gas door lever that opened the hatchback. Easier than climbing over into the back if there is no power.
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I don't know I beat him or her to the hatch back and open it! Also you could stand close enough and he or she could open it.
  4. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    I press the door unlock switch on the driver's interior controls (next to the window switches). That always works for me.
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Yes but you miss when they touch the hatch latch and it opens! Have a little fun!
  6. Three60guy
    918
    Racine, Wisconsin
    So, what am I missing? The keys are in the car. Why wouldn't anyone be able to open the hatchback then?
    Do the keys have to be outside the car?
    Signed,
    Confused over something so simple.
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Doors have to be unlocked. Key fob commands and smart entry do not work when the car is on. You have to go inside and push "unlock" to unlock any other door.
    Unlock it before you get out of the car (if it's still running)... or.. do what you did.. turn it off when you leave the car.. but then you have another startup for the car *shrug*. if the car is warm, you lose a little mpg.
  8. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    That's really odd, Three60. If not that it's cold, I'd go outside and play around with this. Common sense would dictate that when the doors are unlocked the hatch is also. Perhaps using the unlock button on the armrest would solve the problem. I'm gonna have to try this one of these days.
  9. aaf709
    3,862
    2022 Prius Prime
    IIRC, the Prius has an internal sensor which detects the presence of the fob when it's inside the passenger compartment. Since all the fobs were inside, it assumed that an unauthorized person was trying to get in.
    I did what Boxster said and the hatchback unlocked. I left the fob in the car when I made the test.
  10. Three60guy
    918
    Racine, Wisconsin
    Talk about habit......
    In all other cars the unlock switch would not control the trunk. I was associating it the same way with the Prius. But alas, the Prius does not have a trunk. Thanks for the obvious answer. DUH
    :eek: <=== hitting myself on the side of the head.
    Boy, I hate when that happens.
  11. Tideland Prius
    16,501
    hehe, yeah. The hatch's lock is linked to the power door locks.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    when i unlock my doors remotely, only the drivers door unlocks unless i hit the unlock button twice then all doors unlock including the hatch
  13. aaf709
    3,862
    2022 Prius Prime
    Right, and if you don't open the doors in 30 seconds, the doors re-lock (which bugs my wife).
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    yes that is correct, but that only happens to me when im showing off the range of my remote. no one at work yet has been able to challenge my range
