Computer Question? how to delete GAMEFLY
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Dec 23, 2013.
  1. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Yes, probably a computer "geek" type forum would be a better choice, but I am here, so thought I would give it a try.
    Over the weekend had a few relatives over, including some teens and was talked into buying and downloading BioShock Infinite onto my p/c.
    I also downloaded and installed (not really sure I did, but someone did) the Gamefly Download Manager, which randomly pops up on the taskbar, even when no one is messing around with games, etc.
    I tried uninstalling it, but apparently it likes it here and refuses to leave (despite being uninstalled, according to windows). MalWareBytes, Avast and PandaCloud all say my computer is fine, so it is just one of nagging annoying things, but does not seem to do any harm.
    Last time it popped up, I was able to use task manager and find it is hiding out in C:\Users.....
    AppData\Local\Apps\....
    And so on and so forth for another line or two.
    Any hints on what to do, I searched the web and sent a note to Gamefly, but no luck.
    I also tried REVO uninstaller (which did not find it) and another uninstaller top-rated by CNET, again with no luck.
    Thoughts before I try the computer forums?
  2. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    Try Revo. Also look in you browsers "add-ons" and delete as required.
    Download Revo Uninstaller Freeware - Free and Full Download - Uninstall software, remove programs, solve uninstall problems
  3. Mendel Leisk
    41,328
    A windows system? Win7? You could try System Restore (click start and start typing the words in search). Look for a restore point prior to the weekend. You won't loose data files, it just undoes installs and system changes.
  4. cyberpriusII
    1,155
    1,763
    Mars Hotel
    System restore, hmm, I did a restore point middle of last week when I updated WINDOWS 7.
    It won't uninstall the BioShock game, right? Hey, I paid $7.99 for it!
  5. rufaro
    rufaro WeePoo, Gen II
    2,867
    72
    Lost Angeles
    You could also look in Revo—there's a place you can enter the path manually (if you captured it) that sometimes nudges it into finding the right bits to grab.
  6. Mendel Leisk
    41,328
    It might uninstall your game, but maybe you have a registry code or something for re-install. If the only way to re-install is via that pest program, maybe walk away?
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Get the teens you had over the weekend to fix it.
    My middle aged perspective is that anyone under the age of 20 is a computer genius.
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    rufaro likes this.
  9. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Ursle, looked in startup (I have ccleaner installed, so finding startup is easy) and the little beast was right at the top of the list and enabled.
    I disabled it. Hope that will do it. Sometimes, I find annoying programs find ways to add themselves back to startup.
    Thanks, all for the hints. If the startup trick does it, I am happy enough.
    If not, as suggested, since I know where it is hiding, I could reinstall revo or something similar, make sure to do an updated restore and then try to remove.
  10. ursle
    ursle Gas miser
    1,049
    192
    NH
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Since c(rap) cleaner found the program it should be able to uninstall it.
  12. cyberpriusII
    1,155
    1,763
    Mars Hotel
    You'd think so, but the program does not show up on the CC uninstall list.
    Only on the list of start-up programs.
    There is a delete button on that startup list, but I have never used it. Makes me a bit nervous, but nothing ventured....as long as I do a restore, cross my fingers.....:whistle:
  13. frodoz737
    4,694
    2,496
    33
    Look in your browser add-ons like I said before. For Chrome click on the 3 line/bar symbol in the upper right hand corner, then settings, then "on startup" and look to see if the add-on is there to be deleted. In Explorer, click on the gear in the upper right hand corner, then internet options, then programs, then manage add-ons, then delete there. Not sure on other browsers as I do not use them, but should be easy enough to look up. If it does not delete there go to Computer and double click, then look in program files and/or program files (x86) and look for remnants of the program to delete.
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
  15. frodoz737
    4,694
    2,496
    33
