Bad combination meter - DIY worthy?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by THF, Dec 24, 2013.
  1. THF
    THF Junior Member
    71
    MO Ozarks
    So, I have finally had my combo meter go completely bad on me. I also find that, as well as the meter not working, the rear hatch does not op. and these problems may be related. My question is, is it worth doing myself? My dealer wants $450 for part and labor, and I can get the part for about 2-300$. Has anyone else done this? And am I looking at the right part here:
    COMPUTER, COMBINATION METER. METER (PRIUS (NHW20); USA). 2004 TOYOTA PRIUS # 8329147110
    Oh... And is it illegal to replace the odometer yourself?
    Thanks in advance, THF.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The combination of the meter and the rear hatch not opening suggests that you check your 12V auxiliary battery. This is the common element.
  3. THF
    THF Junior Member
    71
    MO Ozarks
    No, I know what my problem is. 100% certain. Not to mention already installed a new 12v battery. Sorry for these typos...
  4. RobH
    RobH Senior Member
    2,372
    987
    70
    Sunnyvale, California
    It's my understanding that repairing the combination meter circuit board takes less that a half hour of bench time. Something to do with the non-lead solder being used.
    So if you can do board level maintenance like changing SMD chips, please try and tell us what you find out. The worst that happens is you destroy an already broken board.
    It would be clearly illegal to change the odometer and/or misrepresent the proper value. But there is no license I'm aware of that is required to work on the odometer. It's just another electronic circuit board.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There is someone in the Bay Area that does repair on these boards, through Luscious Garage. An engineer checked out the board and found, IIRC, that the problem was related to a power up reset circuit that was not working. He replaced some component or other to get it working, but was not going to give out any public details about it, apparently. It should not be too difficult to spend a few hours looking into the power supply circuit, and replacing some surface mount caps perhaps, or an IC, or just reflow the solder. But it would require the right tools for such tiny components.
  7. salguod
    salguod Member
    234
    37
    Columbus, OH
    I would assume that if you replaced the odometer you'd have to report it as replaced and indicate that the mileage was not accurate. I would think that the law would take into account replacement of the odometer. Of course each state is going to have different rules, you'll need to check what MO says.
    I'm curious what is related between the hatch & combo meter?
  8. northwichita
    481
    102
    29
    Wichita KS
    Luscious Garage gives a good technical explanation on this.
    Luscious Garage | Blog | LG TV - Prius Dead Dashboard
    Quoting from site--------------That said, what’s the explanation for the weird behaviors? It’s mostly confusion over vehicle speed: the speedo acts as a gateway to broadcast related information to other “body” ECUs on a dedicated communication bus called BEAN (Body Electrical Area Network) including those in charge of the power switch and the rear hatch.
  9. Patrick Wong
    18,200
    6,491
    No, but it is illegal to misrepresent the car's odometer reading. When the combination meter is replaced by the dealer, the new odometer is supposed to be programmed with the reading of the failed odometer.
    If the combination meter is not reporting vehicle speed, then the hatch switch may not function. You wouldn't want the hatch lock to release if the vehicle speed was some value besides 0, for example. For the same reason, the POWER switch button will not respond if vehicle speed is some value other than zero - unless the switch is held down for more than three seconds to override that safety feature.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  11. THF
    THF Junior Member
    71
    MO Ozarks
    I am not sure of what MO laws on the odo are. I would assume no one would say anything if the odo got set the same or higher, but then again, it's never safe to assume anything.
    Since the combo meter reports speed to the car, the back hatch usually won't open when the combo meter goes out. Although, recently, it goes out even when the combo meter is on. (It works intermittently.)
    Eeep... Well, you may well have answered my question for whether or not I actually want to do it myself. With the much dashboard work, I'm bound to break some of those stupid little pegs on the dashboard. I'd rather just pay Toyota the $150 to mess with all the pegs. (I'm always against someone else doing what I could do, but in this case, I really think I would probably break something.) Then I'm afraid of the soldering because, despite being a computer nerd, I never actually soldered anything.
  12. vskid3
    vskid3 Active Member
    773
    228
    I think the risk of you breaking anything taking the dash apart yourself is pretty low. I took mine apart almost as far as you'll have to (except the top piece that goes across the whole dash) when I replaced the headunit. I don't think I've ever been less worried about breaking a tab. Everything seemed to come apart very easily if done the right way. So don't let that deter you.
    My dealer let me keep driving my car while they waited for the part and I didn't get a chance to take it in for them to replace it until a couple weeks later. I ended up losing about 300 miles between them. Worst part is it messed will my mileage log. :p
  13. THF
    THF Junior Member
    71
    MO Ozarks
    Well, I find that encouraging, although it stillseems daunting, possibly because I've never done anything like that before.
    So them my other question is, do I really want to buy a used one? Seems to me it might just go out again. So, on the other hand, can I buy a new one with the correct mileage? I would trust myself to order one with the correct mileage, but who else would?
  14. Patrick Wong
    18,200
    6,491
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    The used meters sold by autobeyours.com are picked to ~ match the old odometer reading. So long as the replacement meter shows at least as many miles as the old one, I would not worry about law breaking.
  16. THF
    THF Junior Member
    71
    MO Ozarks
    Ok... So my next concern is picking a meter with the same or close to mileage as my car. Does anyone know if they can be factory set? Because that is what Toyota was going to do.
    Thanks for your help guys!
  17. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Yes the odometer can be altered with the correct equipment, but finding someone willing, and able to do this is the big problem.
    John (Britprius)
    THF likes this.
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yep, that is why I mentioned autobeyours.com. They have an inventory of used meters of different odometer readings which lets them pick one that is close to the reading the customer has. Since old meters are not discounted, I would just take on faith that the owner Steve will replace or repair a bought meter that craps out early. His reputation is that good.
    Luscious Garage thinks that all CMs will eventually die, but they also point out that almost all the failures they have seen are in taxis. So I personally would avoid buying a used CM that came out of a taxi, but otherwise would feel pretty confident buying used.
  19. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Question, since the odometer reading is a digital display, is the digital data stored on the instrument panel or internal to the ECU? My guess would be internal to the ECU.
  20. Britprius
    5,194
    1,918
    It is stored in the combination meter, but it is no clear if it stored somewhere else as well. This I doubt but it is possible.
    John (Britprius)
