2010 Prius Grill Blocking strategy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ken1784, May 31, 2009.
  1. markabele
    5,084
    1,782
    Nebraska
    Mine is still in the mail. I will report back once I have it working for a bit.
  2. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    This is what I've been using...
    markabele likes this.
  3. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Ditto gliderman's question.
    Mark,
    What brand, part number, cost and where are you getting your cheapy OBD II Blutooth adapter? Is the same one you got one year out of? Yes, we await your devices arrival for your feedback. :cool: (cheap &) Inquiring minds and all... ;)
    John,
    Thanks for your device info. Can you tell us how long (and how much) you have been using it? What is your review of your device?
    Others,
    Can you report in with reviews of OBD II devices (preferably inexpensive) you have purchased with short review (1 star to 5 stars? :D ). Dimension that it protrudes from OBD connector would be helpful. I've read that some adapters are taller and stick down more and are more prone to bumping and breaking the device while plugged in, especially if you leave it in most of the time.
  4. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I see in PlayStore Torque lite (free) and Torque Pro ($4.95). $4.95 is certainly inexpensive, but I thought I would ask what you guys recommend. Torque Lite or Pro. Just in case there is some kind of a downside to Torque Pro (vs. Lite).
    Lite rated 4.3 by 4,570 reviewers, w/ 1,000,000+ downloads
    Pro rated 4.7 by 16,700 reviewers, w/ 100,000+ downloads
  5. markabele
    5,084
    1,782
    Nebraska
    I don't think you can add the PiP PID's on lite.
  6. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    True.
    In Lite version i cannot communicate with OBDII (Xperia Arc C + Android 2.3.4). With Torque Pro no problem with BT connection. Not to mention really nice graphic interface and capability. Do not hesitate.
  7. john1701a
    12,794
    5,276
    57
    For everyday, always available use, you can't top a ScanGauge. But the data available is quite limited. For example:
    The use of an app requires a smart phone or tablet, which runs down its battery and requires mounting each time you drive. It can be far more informative though. See:
    I actually have both devices connected all the time. I purchased an ODB-II splitter, which has worked like a charm. So, I use the ScanGauge constantly. Bluetooth for the app is mostly limited to filming and rare other occasions when I want to know more.
  8. markabele
    5,084
    1,782
    Nebraska
    Who's gonna make the first Google Glass video while hypermiling?
  9. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    John, Thanks for the great info & video. Reading on Amazon reviews it seems ordering one item, you may get something different with lots of variability on if it works with some phones/cars. argh.
    While running Torque Pro, can you make and receive BT calls as normal thru car's speakers/mic.?
  10. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Anyone using an OBD2 to Micro USB cable to connect their Android instead of a BT adapter? Only cable I found was with a regular USB connector.
    But then I could not find a female/female connector to connect this to my USB/ Micro USB charge cable.
  11. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I just ordered the adapter John linked to above. I should get it tomorrow (paid $3.99 for one day shpg). I'll download Torque Pro later and check it all out.
  12. Flying White Dutchman
    4,376
    313
    someone in the bay area? :p
  13. john1701a
    12,794
    5,276
    57
    Most likely. I haven't actually tried that. But on the drive home today with Torque connected and streaming music, I got a text (audio via the speakers) and replied with a preset message. That's 3 different Bluetooth services active all at the same time with the same device.
  14. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Very good to know. The adapter will hopefully arrive today, albeit likely in the evening. Then I'll need to steal my wife's Android phone to download Torque Pro. I understand with Torque Pro you can disable the back up bell (gotta remember where I saw that). This will make my wife VERY happy. Hopefully enough that she won't mind me learning and playing with Torque while we drive to the family Christmas gathering tomorrow. :cool:
  15. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Here you go Dave: GenIII Prius Custom PIDs for Torque app | PriusChat
  16. markabele
    5,084
    1,782
    Nebraska
    Just remember to select your gauges when it is disconnected from the car.
  17. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Thanks for the link. So I have to download some file, find it on the PC and do something with it... :confused: Assuming I get this LG G Pro 4.1.2 to ever detect the BT adapter ( no luck yet :( ), I will need to venture into the unfamiliar PC world (wife's laptop, I am a Mac person), to try to see if I can figure that out. Tough when the OS is so foreign to me, but I will give it a go later.
  18. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    New to this. What are 'gauges'? And I guess disconnected means well out of BlueTooth range, or BT turned off, right.
  19. skaterazn
    skaterazn Junior Member
    I have torque pro with the custom pids installed.
    Can someone tell me which are the important values? And when they become critical?
    Thank you in advance.
  20. gliderman
    gliderman Active Member
    751
    225
    I watch your gauges in complete awe. My ICE never completely shuts off unless I am going below ~20mph. It will only go as low as about 920 rpm, but it is always on unless I brake. You show acceleration in the 40's and 50's with 0 RPM.
    Should my 2010 Prius ICE be turning off at higher speeds when coasting or lightly accelerating? That may be why I never see MPG like many of you get. There is no way I could get 60 MPG. My best is 56 MPG.
