"Plug" running hot....?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by samsdad, Dec 25, 2013.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, that's the amber led drawing current
  2. ETC(SS)
    7,131
    Define: HOT.
    Anybody that's old enough to to have actually had to place a computer in your lap will remember that sometimes electronics can get kinda warm.
    As stated above, my rule of thumb when I worked for the government was that if you could hold it or touch it for 30-seconds?
    It's not HOT.....it's warm.
    Then?
    It becomes a matter of WIN-WIN....or what is normal? What is not?
    The plug itself should never be HOT.
    It can be "warm" for many reasons, such as sunlight, inquisitive felines, etc.
    If you're charging from an exterior GFI outlet on a circuit that's breakered (or fused) at least for 15A?
    There's very little chance that the plug is getting warm from anything evil in the house wiring...but I'm a little curious about what you're using for a timer.
    I'm not a Pip owner yet, so this may be a feature that I'm unfamiliar with.
    Good Luck!
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ETC(55) the timer is built into the PIP, not an external timer
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I was going to rec. that the OP buy one, Around the house it is. more useful than a multimeter. It gives you Current drawn, Potential Voltage and Watts, or Kilowatts.
  5. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Oh, THAT's what PV means! I just Googled to see what it is, but my eyes glossed over. :confused:
    If there is a one or two sentence description of PV, I'd love to know it. If not, never mind. ;)
    (If I remember, I can ask and electronics buddy next time I see him. :)
  6. markabele
    5,084
    1,782
    Nebraska
    In this case that's what it means, but most times when used on this site it is referring to photovoltaic.
  7. bisco
    51,832
    and here i thought it meant photo voltaic.:cool:
  8. ETC(SS)
    7,131
    Thanks.
    I'll add that to the list of things to like about the Pip.
  9. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    There is also just 120 volts present in the OEM EVSE, not 240. Although 120 can be more dangerous to your heart than 240...
  10. Andyprius1
    2,327
    859
    Cool CA
    . Not at 1/2 the current.
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Actually the "brick" is a transformer which doubles the 120 vac to 240 vac:D
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Also......when you double the voltage from 120 to 240 the current at the 120 end is 12 amps whereas at the 240 end it's 6 amps. that's why it takes longer to charge the battery with the brick vs a direct connection to 240 volt outlet
  13. Andyprius1
    2,327
    859
    Cool CA
    . And in a normal transformer twice the voltage = 1/2 the current. Theory is not applicable to all situations and circuitry, just a general Phisics law with a 2:1. or 1:2 Transformer, disregarding all other present impedance and frequency &/0r. cable losses. Remember always keep your cable stiff.
    priuskitty likes this.
  14. Andyprius1
    2,327
    859
    Cool CA
    Excuse me Kitty, I forgot you were present, for you it should read always keep your cable slack!
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    That's why extremely high voltages are transmitted over high power lines, you can transmit lower currents over long distances. then use transformers to lower the voltage to get the higher current locally at the home. :D
    Andyprius1 likes this.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'll leave if you want
  17. Andyprius1
    2,327
    859
    Cool CA
    As long as the boys are not offended.
    markabele likes this.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    another "female" crack?:rolleyes:
  19. Andyprius1
    2,327
    859
    Cool CA
    Certainly all females have a perfect right to use their PC forum, and above all you "Prius Kitty have the most right. I'll keep my wise "cracks " to myself. What was the subject matter?
  20. bisco
    51,832
    what's wrong with female crack?:cool:
