Just got a scanguage today, what to do?
Discussion in 'Prius c Accessories and Modifications' started by DKTVAV, Jan 9, 2014.
  1. DKTVAV
    DKTVAV Active Member
    510
    101
    I tried to search for a thread where people mounted theirs and what needs to show on display but couldn't find it. I believe I've seen some pics or videos DIY and also something about downloading a file to do something with. Any suggestions?
  2. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I use Velcro to mount mine to steering column. You will need to set the gauge up to match the C. That will be in the manual that comes with the unit. I have been running a ScanGauge for several years and really like the simplicity of the unit.
    Dan
  3. DKTVAV
    510
    101
    I just mounted it last night after having trouble routing the cable. I didn't use Xguage yet only went thru advance settings and happy to see it's turning off when the car is off.
    What are you having on your screen? I think I will use the RPM and the most important to me water temp, not sure the other two though.
  4. WD0AFQ
    619
    152
    Dexter, Mo.
    Don't know why you should have trouble running cable, lots of room and choice of side or rear plug in. I run rpm, engine temp, instant mpg. I find instant mpg right in front of my eyes along with the dash average is very helpful to me. Voltage is fourth now but I switch it around. The tank average mpg is always right on when used with gallons used. If it says it needs 8 gallons to fill it that will be exactly right once you get everything set just right.
    I bought an ultra gauge to play with but like this one better because of the simplicity.
    Dan
  5. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    I use LOD, C°WT, AMP and SoC.
  6. DKTVAV
    510
    101
    In this table:
    I found 2 soc but none of the rest. What are they and where can I find them?
  7. DKTVAV
    510
    101
  8. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi DKTVAV,
    There are 3 worksheets in my spreadsheet, you can choose your preference for units of measurement; US or Metric at the bottom.
    Vincent
  9. DKTVAV
    510
    101
    Hi vincent1449p,
    I did search your worksheets in both US and Metric but couldn't find LOD, C°WT, AMP and there are 2 of SoC.
  10. vincent1449p
    894
    331
    Singapore
    Hi DKTVAV,
    LOD and C°WT is from the built-in gauges in SGII. In my spreadsheet, cld (row 111) and eCt (row 118) do the same function of displaying Engine Load and Water Temp respectively.
    AMP is from GenIII Xgauges (row 25), I use a different name, IB (row 271).
    SoC (row 167) and SOC (row 185) display the same State-Of-Charge. I use the former because my SGII firmware is older ver. 3.17 and cannot display multi-frame msg. You need firmware 4.xx to display the latter.
    Vincent
  11. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Vincent's covered it, but note you will see F°WT instead of C°WT in the built-in gauges if you don't have the device in metric mode. It's the same information, just different units.
  12. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I'm using MPG/GPH and RPM/FWT
  13. DKTVAV
    510
    101
    I'm using:
    RPM----------f°WT
    MPH----------LOD
  14. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I monitor inverter coolant temp, engine coolant temp, RPM & MPG.
