ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. El Dobro
    El Dobro A Member
    7,086
    3,263
    Changed the trans fluid today. The old stuff was darker red with a little bit of a silver sheen to it. When I finished, I thought I saw one of the headlamps wink at me. :D
  2. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Does anyone recommend a dealership in the Los Angeles/ Orange County region for the ATF flush? I've had one dealership quote me $230 and another $180 for my Prius C...
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    No flush, just drain and fill like an engine oil maintenance. DIY and save $150 - $200.
    Fostel likes this.
  4. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    I get it's a simple drain, but I'd rather have someone that knows what they're doing do it for me. I'm just not willing to spend double what it should cost.
  5. frodoz737
    frodoz737 Top Wrench
    4,689
    2,492
    33
    Inform the Service "Manager" nicely that you know this is a drain and fill...not a flush...and that most dealerships charge $99.99 or less. Service "Advisers" hear ATF and go right to flush in their minds which is more expensive and not applicable to this vehicle. Not all Advisers are the brightest, though most know their stuff. If they don't budge, walk away because they will just f-ck you from that point on as they lack integrity.
    Fostel and PriusC_Commuter like this.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    On that note, it "should" cost the most they can squeeze from you. This is America after all, where exploitation of the hapless is a virtue. I hope you do not mind.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Only if you pay the price they ask. You don't have to.
  8. Bill Norton
    Bill Norton Senior Member
    2,143
    734
    MONW, Ks.
    " Momma says,,,, You better shop around"
    You know it doesn't have to be a Toyota shop.
    Fostel likes this.
  9. Mendel Leisk
    41,304
    I think a big part of the confusion and price spread on this service goes back to Toyota. For whatever reason, they say officially a transaxle fluid change is never needed. This can't be helping their service managers, writers, and mechanics.
    I'm not sure why they're so steadfast on this, that the fluid in that transaxle is good, well, forever. I would actually like to get to the root of it, understand their rational, however misguided or chauvinistic.
    My best guess is it's a misguided attempt to impress owners with low maintenance, thus make more sales? That's not sold well here though, LOL.
    FWIW, coming from 30 years of Honda ownership, the Prius Owners Manual is the first book I've seen that doesn't give you an oil change how-to. Seems like they have a dim view of DIY.
    frodoz737 likes this.
  10. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Yes, I suspect Toyota marketing and sales push aside the engineering department for profit. This isn't exclusive to Toyota, it's an industry-wide issue. Who is left holding the bag on the manufacturer's empty promises? Consumers.
    In the Prius Owner's Manual, there should be instructions on oil changes and air filter replacement. Specs are incomplete,, such as total fluid capacities for engine and transmission. Toyota treats the Prius as if it were an iPod, not an automobile. Obviously, they expect everything to be dealer serviced, even the simplest maintenance tasks.
    Fostel likes this.
  11. Former Member 68813
    3,524
    983
    US
    There is no conspiracy here. Simple explanation. It's my understanding car "lifetime" is defined as 150,000 miles. Car engineers run a sample of cars to 150,000 miles of real or maybe even simulated driving, had no tranny failures attributed to oil, did oil analysis and decided oil was good enough for the "lifetime".
    Fostel likes this.
  12. Bill Norton
    2,143
    734
    MONW, Ks.
    But, but, what about the oil analysis I did at 108k miles?
  13. Former Member 68813
    3,524
    983
    US
    It was 112,000 miles IIRC. You data point is the far right one. Consistent with the trend.
    chart | PriusChat
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    What trend ? It looks like a plateau after 30k miles.
  15. Bill Norton
    2,143
    734
    MONW, Ks.
    That chart is an interesting way of displaying crud in the ATF, yet it minimizes how bad my sample was.
    The chart shows a trend, not actual results.
    Correct, my first sample was from 112k miles and it was so 'Dark' that the 'Particle count' test could not be performed because it is a light based test.
    You bet on my new car I will be doing an early ATF change and posting the analysis results. It calls for the first change at 97.5k miles. I may do it at 40k. And that is actual car miles. I changed the engine oil at 2500 Gas miles.
    It didn't look good but I didn't do an analysis.
    I'm currently at 6115 EV miles and 10,024 Car miles.
    (EV miles cost ~20% what you guys pay for fuel.)
  16. Former Member 68813
    3,524
    983
    US
    Right, your 2nd particle count did indicate abnormal wear indeed (large particles). However, it didn't fail and probably would have made it to 150,000 miles on the OEM fluid. Not much longer though. Did you sell the Prius because of it?
  17. Bill Norton
    2,143
    734
    MONW, Ks.
    No, I felt that the ATF degradation could be stopped by regular ATF changes until the analysis reports trended to normal.
    Another issue was; on a heavily loaded, fast trip from KC to Chicago to DC to KC, I saw slightly less than 3000 miles per qt. of engine oil. But I'm pretty sure that oil consumption is related to power levels of the engine.
    (My pal with the 350k mile Gen2 sees this on his 500 mile a day bank courier route. He's a data gatherer like no other!)
    I sold the Prius when I crunched the numbers comparing it to a Volt. This was at the time of the $5k price drop and leftover '13's where out there. Even though I shouldn't have,,, for ~$8k more I could have the highest tech car on the road !! With a nice new warranty and theoretically have a payback someday!
    I can go weeks without that smelly gas burner coming on. I use a 'Killawatt' at home and I see ~$38/mon. in electricity usage. But I get to plugin at work and top up for the trip home. I work for a progressive high-tech company that made their fortunes in the automotive segment, so they sort of embrace the future of automobiles,, after some coaxing..
  18. Former Member 68813
    3,524
    983
    US
    Congrats. I'm also eying Volt as my next car. Looks like by waiting I'm going to miss the tax rebate. Did you get yours?
  19. Bill Norton
    2,143
    734
    MONW, Ks.
    Tax rebate should work this year.
    Waiting for all the other forms to file.
    I may even get an incentive on a 240V charger I just bought.
    I was doing fine with the stock charger but for winter 'Preconditioning' and weekend trips it will be great to have.
    $250, it's a kit from one place and a cord and connector from amazon.
    Did you know the PIP only gets a $2500 break because it's such a lame 3 season EV and you can't accelerate much with it or you burn gas?
  20. Mendel Leisk
    41,304
    We're spending about that on gas, and at higher Canadian prices, LOL. Of course, that's with very low use, right now barely 1000 km's monthly.
