Maintenance tips requested for long-term ownership
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Raidin, Jan 12, 2014.
  1. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    Understood. Just to add, ATF should cost no more than $99.99
  2. jdenenberg
    jdenenberg EE Professor
    3,919
    1,917
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The three above are reasonable, if a bit high
    There is no flush, just a drain and refill of each of the two loops (ICE and Inverter)
    My dealer does this for $100 as mentioned above
    I'm not sure that I would let this dealer work on my Prius.
    JeffD
  3. frodoz737
    4,509
    2,430
    33
  4. Raidin
    Raidin Active Member
    238
    183
    Houston, TX
    I keep saying coolant flush but I mean drain/refill. Just a habit.
    Just for reference, they charge $14 for the 5000 mile interval tire rotation and inspection, and about $66 for the oil change / inspection on the 10,000 mile interval. The 30k service interval is about $200.
    I'll call some other dealers and check their prices this weekend.
    ztanos likes this.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    $14 to rotate the tires? That is free at every place I have ever taken my car. $66 for an oil change? Jebus... that's high too.
  6. Mendel Leisk
    40,492
    ^ I sure as hell wouldn't rotate someone's tires for free. Would you??
    If it's free it's because it's a "loss-leader", a ploy to get you in the door.
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    They give it free to get you in the door, exactly. It works, too. I've had tires plugged for free as well. I've never paid for a patch.
  8. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I will recommend exactly the opposite.
    Because of the computer controlled regenerative braking, any brake work that needs 'bleeding' to be done, needs to be done at a dealership. There is Toyota specific software to defeat the usual regen and allow a direct line from the master cylinder to the slave cylinders.
    Spark Plugs, Coolant, and ATF labor (get the fluid from Toyota) are well within the expertise of a DIYer, or any mechanic. You will find step by step "how to"s here. (and rants about trying brake jobs on your own)
  9. Raidin
    238
    183
    Houston, TX
    I decided to hit up Repairpal.com and find good mechanics in my area. There were only two certified by them, and one is next door to where I live. After talking to the owner, here's what I found out:
    • 5k Tire rotation intervals are about $20 (dealer charges about $14)
    • 10k Oil change intervals will be about $45 (dealer charges about $65)
    • 30k Oil change + both filter intervals are about $75 (dealer charges about $200)
    • 100k interval with the coolant drain/refill is $120 (dealer charges about $180)
    • 120k interval with the spark plugs replaced is about $200 (dealer charges about $180)
    • ATF is $200 (dealer charges the same)
    • Brakes are $200 per axle, same as dealer. Apparently the $99 for entire brake jobs is just a con, according to him.
    • Brake fluid change would be $50 (dealer charges about $100)
    • PCV valve is $20 to replace, which he recommends at around 100k miles just because it's so cheap, so worth the investment.
    Transmission and coolant will be using Toyota fluids, oil will be different. He also says there's no value in full-synthetic, because normal oil has gotten so much better now.
    The owner also recommends oil changes at every 5k miles instead of 10k because of independent lab tests showing most oils break down long before 10k miles.
    I also used Repairpal.com's estimate system and it produced correct values for what I found and have been paying, for my area. Maybe it's just more expensive around here.
    What do you guys think?
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I suggest sticking with synthetic. Bouncing back and forth can do weird things to the gaskets and seals.
  11. Raidin
    238
    183
    Houston, TX
    I was thinking the same thing. Figured I may as well, not a big deal. It will raise the $45 to about $65 or so, but worth it imo.
    ztanos likes this.
  12. Brad K
    Brad K Member
    173
    53
    those prices seem ridiculously high
  13. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Negative. This is not true. You can go back and forth from conventional to synthetic and back again at each oil change without incurring gasket or seal problems caused by it. Perhaps it was true in the 70's, but not in the last 20 years, at least.
    However, to stay with the recommended 0w-20 would practically guarantee you will be using a synthetic oil, as I don't think there is a conventional 0w-20 yet. A conventional 5w-20, while not recommended in the owner's manual, is entirely ok to use for 5k mile intervals on the C. With approx 20% or more of the 5k miles being with engine-off, it would be will within the range of the abilities of conventional oils. Oil recommendations outside of North America show the ability to use any weight oil shy of gear lube...even 50w oil, in hot climes. You would see decreased mpgs, and perhaps sluggishness on colder days, but that's about it.
    I'll let others discuss mechanical maintenance items. I do my own work so the cost is for just parts and tools. The tools paid for themselves many years ago, and I would say to buy jack stands and a 2.5 ton hydraulic jack now so you can start changing your oil and rotating your tires now. They will last your lifetime and save you money every time you use them.
    What I would like to talk about is keeping your car looking good for all those years you will have it. Hand wash it. Wax it two/three times a year, every year. Wax gets easier all the time, and doing each panel twice can be done in an hour or so on a Saturday or Sunday morning. Clean your glass inside and out at least once per year. Twice would be better. Vacuum your carpet. Wipe down your dash, doors, seats, trim, and console with a damp cloth twice per year. Spot paint chipped paint. Remove tar from the wheels. Clean the salt and dirt off the car regularly during the winter.
    Make you car worth looking at through the years and it will pay off in increased value when you finally say goodbye to it.
    Palmoyas likes this.
  14. Mendel Leisk
    40,492
    Apart from the ATF replacement, which seems a bit high, should be around $100, the rest look about right to me.
  15. clgutierrez
    clgutierrez Junior Member
    51
    17
    Mr Incredible, 0w20 is one of options for the my Prius C down here. That oil has the same 10k kms change period than 5w30, which incidentally is the lowest oil I have been able to find.
    Maybe in 10F temps the grade could make a difference, but in more temperate climate Toyota doesn't think so.
    Sent ?
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Colder temps Toyota recommends the 5w30. For some reason the US cars have 10k miles between oil changes. Canada has a 5k service.
  17. Mr Incredible
    955
    506
    Neb
    Marketing.
    Mo G, Mendel Leisk and ztanos like this.
