  1. ckam1989
    ckam1989 Active Member
    185
    358
    Irvine, CA
    2014 Prius Plug-in
    I finally got around to Plasti dipping my emblem(s) and add the umbrella stickers. The letters were a challenge. Must do the side and front emblems tomorrow or early next week.
    I got my carpool stickers today too. I can finally drive carpool : D
    Infini likes this.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Maybe I missed this thread but can u explain this a ill more?
    VS980 4G ?
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    1. Installed lower exterior door moulding:) .H
    Bullet Salvador likes this.
  4. Ajwatuc
    Ajwatuc Junior Member
    75
    It was in reply to my post. He asked what vehicle the shift knob came out of. I replied and he replied with the statement above
    1973 cb500
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Haha, I was wondering more about his break click.
    VS980 4G ?
    Infini likes this.
  6. David2sav
    David2sav david2sav
    107
    171
    San Jose, California
    Been quite a while... finally got two mods that were long over due. Jdm steering wheel and new pedals, both products from MIT on ebay.
    Dylan Doxey, ncmm87507 and Dawit like this.
  7. Infini
    Infini Member
    169
    30
    Los Angeles
    I have those sitting in a box for months. How was the install of the pedals?
    Also was your steering wheel a bit off? I need to re-install it.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That's common with JDM steering wheels. I just had an alignment done to correct it.
    VS980 4G ?
  9. xliderider
    xliderider Senior Member
    8,083
    3,236
    Honolulu, HI
    Infini was advised to adjust it via the tie rod ends previously. I guess it never happened.
    SCH-I535
  10. Infini
    Infini Member
    169
    30
    Los Angeles
    Adjusting the tie rods are not really an efficient way to help the car though. I know it's common guys. But not always the case of the aftermarket part being at fault. Might be with me but I put mine on without checking if the wheels were exactly straight. they were off a tad. Also it's been shared that getting an alignment does not always do the trick.
  11. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It's not a matter of the aftermarket part being at fault. The splines aren't exactly the same as stock or even between OEM steering wheels. Nine out of 10 times the splines won't line up exactly the same, requiring adjusting the tie rods. This is also true if you replace it with another OEM steering wheel. That's why you can have up to 1.5mm difference (1-turn of the tie rod) and still be within spec according to the service manual.
  12. Infini
    Infini Member
    169
    30
    Los Angeles
    It does not matter. I was not asking people here for advice lol. I was asking the OP if they had this problem. I have been paying attention to the threads on this particular problem thanks. I do not know why this has become something it's not. He answered. It's over.
  13. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    weather techs, and 35% tint all the way around..
    Dylan Doxey and Infini like this.
  14. Infini
    Infini Member
    169
    30
    Los Angeles
    So again - the steering wheel (lol) were the pedals hard to install?
  15. Lucky Lager
    Lucky Lager Junior Member
    87
    Well Im getting it tailored to my liking. I am weird about steering wheels, I have to have a cover, not cheap Wal-Mart ones, I like the Wheelsking real leather that you lace up. I hate factory feel of most steering wheels, The Prius' was pretty bad, I hate the feel of plastic. So I wrapped her up last night, installed my TOYPD2, threw on some FIAMM horns and installed Weathertech Ventguards, Ive always like them, I know some people don't but I like their look. Im still waiting on my ESS switch, Splash guards, Weathertech floor mats, New wheels n tires and am still searching for a LCD AD rearview mirror and BU cam. Here are some pics, didn't really take too many, but I know if you cant back it up with a pic it didn't happen:)
  16. Infini
    Infini Member
    169
    30
    Los Angeles
    Love that pin stripe. I used to always buy those leather steering wheel wraps, spend an hour putting them on every car lol. They are cool but my OEM steering wheel had an all leather wrap that I think is better looking but a bit more cushy than those plus the string never comes loose.
  17. MarcSmith
    471
    150
    Northern VA
    I though about a pin stripe. but I have a thing for navy blue. not sure navy blue pinstripe would look good on a white car with grey interior
    Infini likes this.
  18. Infini
    Infini Member
    169
    30
    Los Angeles
    Ok some left over things Sean installed today we were supposed to do last week but ran out of time.
    No more bulky CB truck driver looking wires hanging on the dash lol! That's my HD video GPS Black box.
    This is the rear break light bar blinker mod.
    This is the new in car modder. Lovely add on don't you say?
    Again thank you Sean for the follow through and good work.
    sfv41901 likes this.
  19. Lucky Lager
    87
    Thanks guys, I buy steering wheel cover for every car they just feel good, I'm
    Usually against pin striping and take it off immediately, compound buff n wax but this pin stripe works for me so I left it.
    Infini likes this.
  20. David2sav
    David2sav david2sav
    107
    171
    The steering wheel wasn't off at all. Lines up perfectly but I took my time with the install. All the pedals were easy to do, but I did have difficulty with the gas pedal. I used a flathead screwdriver to pry the back of the plastic over the pedal slowly. Its the hardest install cause its the only pedal that you go over the original rubber.
    Infini likes this.
