"Plug" running hot....?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by samsdad, Dec 25, 2013.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    maybe it's tripping it when the charging is at the last ten minutes of charging, because I have monitored the voltage and current using a data logger and using Excel displayed the current drop from 12 amps to 6
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    that's a picture of my data logger hooked up at my local ChargePoint station
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I'm not clear on what you mean there. I just did some checking, though, and I think I know what has you folks confused: an EVSE does contain a little transformer, and it does accept 100-240 volts. *However*, it takes power supplied by the house circuit and uses it to *power the EVSE*, not to charge the car. Further, EVSEs with J-1772 plugs are largely interchangeable: a Leaf EVSE will allow a Prius PHEV to charge, and vice versa (I've done this). The Leaf EVSE does not convert 120 volts to 240, yet it can "charge" a PIP. Therefore the PIP's own EVSE does not supply the car with 240 volts, except maybe at the proximity sensor, with L-2 charging. If that's what you were all talking about, then this has been a huge waste of time for everybody, I'm afraid...
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    check out this thread.........
    home wiring failure | PriusChat
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    me2, I did some checking, not very clear though
    http://www.sae.org/smartgrid/chargingspeeds.pdf
  8. bisco
    51,561
    samsdad, it sounds to me like something is amiss in the outlets/gfci's the electrician installed for you. i would have them come back and take a look.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thats how I have mine! No problems.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    No, but I did run a 12 gauge dedicated line to my outlet.
    priuskitty likes this.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    how's the weather there? hit zero yet?
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    44 degrees today, but I'm holding on to my socks!
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lol, zero here on new years eve:eek:
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Just check weather 49 degrees today but Sunday low -15 , Monday -13, Tuesday -10 Highs in the low digits 0 t0 -4.
  16. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    "Crack" always brings to mind Bart Simpson in a cartoon next to a plumber working under a sink, with the caption "Crack Kills!"
    This is NOT the one, but relays a stronger message. :eek:
    Google Image Result for
  17. samsdad
    samsdad Junior Member
    40
    Long Beach, CA
    Final Update: My electrician figured out the dedicated outside outlet I was using was NOT grounded. Yikes! Ran a quick ground to the nearby water pipe, and everything is working fine now. Here's the charging set up....Thx for all the replies.... image.jpg
  18. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    There is an easy way to test for ground - no electrician needed. Just get a $3 test light and touch it to both the Hot (smaller) slot and a metal part of the outlet, like the center cover screw or the case. If it lights, the outlet is grounded. (In the case of the box, it means the box, at least, is grounded. Check the outlet too.) If there is no light, try the neutral (larger) slot: if it lights then the outlet is wired with reversed polarity, and should be fixed.
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Glad you resolved the problem, thats Great! :)
  20. bisco
    51,561
    i thought this was the weather forecast thread. thanks for derailing.:cool:
