Plug-In Road Rage: It begins
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Jan 21, 2014.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    All plugin should have equal opportunity to plug.
    Well, except the ladies are first. If both owners are dudes, first comes first served.
    Giving higher priority to BEV, should be a courtesy.
  2. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    No way 8-hrs work days?...but I agree totally re: philosphy (age has it's advantages...not many, but some)
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Special charger you got there.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    If you're talking about the former Yahoo in the Mercury News article, I personally know him (but I've never worked at Yahoo.) He was a former Leafer but has an ActiveE now. I'm guessing he had an ActiveE at the time of that "incident".
    FWIW, at my work L2 charging is free and even though our ratio is ~4:1 (of plug-in vehicles vs. L2 EVSEs), we're actually VERY well behaved and self-managing with respect to charging, freeing up spaces when asked, plugging in waiting cars, etc.
    During the time I've been there, the only thing even remotely close to charge rage that comes to mind is when (IIRC) a Volt driver accidentally unplugged another Volt that wasn't done and closed their charging door) but forgot to ping the "victim" as an FYI.
  5. Scorpion
    Scorpion Active Member
    440
    162
    Lincoln, NE
    Well good catch.
    I meant 1.25 kw x 8h = 10 kwh, (but 1.125 kw or 9kwh) is still enough to cover best selling PHEVs
    Not sure if that is what you are talking about, or if you are doubting 1.25kw plug-to-batt for 110v
  6. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I passed a free L2 charger in Hermosa Beach since I really didn't need it and figured I'd be a good person and leave it for a BEV in need. Turns out I accidentally parked next to a car in a motorcycle spot recently converted from a regular space without realizing since it was dark and got slapped with a $48 ticket... Last time I ever turn down an open charging space...
    Two things. One, it amazes me these chargers don't lock to your car while you're charging and unlock when you're full. Two, it would be nice if there was a standard on colors and lights to tell when a car is charging versus full. Sure you can deduce it, but it'd be nice to have a standard.
    Scorpion likes this.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I haven't seen any evidence to suggest that is true of the i3, unless your home is near the summit of the local mountain. The i3 range extender can put out 25 kW and it probably takes 15 kW or less to drive it at 55 mph on a flat highway.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    My back-of-envelope calc suggests that 25 kw will move a car up a 5% grade at around 40 - 45 mph.
  9. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Sure, substantial hills are likely to be a problem on the range extender with an "empty'" battery.
  10. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Blame the lousy engine! :rolleyes:
    dbcassidy and cwerdna like this.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  12. telmo744
    2,181
    769
    Portugal
    PiP had a wheel over a cord.
    Volt owner couldn't charge, decided to swap and did realize that the 2nd cable couldn't plug the PiP anymore.
    Volt slot is near driver door, it had enough length as far as I see...
    edit: "as far as I see"...
    My bad, the Volt is parked at the left...
    It raises a question: can anyone simply unplug other's car?
  13. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I agree and wouldn't consider anything else more fair or reasonable. That would surely take the fun out of owning a pure EV for sure, and will probably deter me. As with most things in my life, I'll make my own way and not count on others for fairness regarding anything I can't control.
  14. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Presumably, the PiP driver parked on the charge cord unintentionally. I think the Volt driver was wrong to unplug the PiP while it was still charging. I can't imagine a good reason for doing that in order to plug in another car with a range extender.
    I have unplugged other cars in order to plug in my Volt but only at locations with free parking and charging, after waiting 30 minutes beyond the end of charging, and when they had overstayed their garage parking privilege (for example, a general 3 hour parking limit). I didn't feel obligated to let them hog a free parking and charging space all day long.
    telmo744 likes this.
  15. TorqueNews
    TorqueNews Junior Member
    Frankly speaking, it was just a matter of time from happening. We see EV ownership growing at a faster pace than the chargers. I would put few extra chargers in the parking lot if I was an:
    A. Restaurant owners
    B. Shop owner
    C. Mall parking lots
    D. Grocery shopping store
    E. Office building owner
    F. Gas station (looks like a no brainer, but why most gas stations don't have chargers yet?)
  16. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    It makes no difference because wireless is embedded on the ground. it is still a charging spot.
    The Rage will be even worse as it has nothing to unplug and may resort to vandalism.
  17. TorqueNews
    Wireless charging would be excellent solution.
    dbcassidy likes this.
  18. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
  19. Zythryn
    Zythryn Senior Member
    6,408
    4,406
  20. frodoz737
    frodoz737 Top Wrench
    4,625
    2,483
    33
    Entitlement - Definition and More from the Free Merriam-Webster Dictionary
    THIS IS THE PROBLEM.
    The fact I see is that different segments within this group can not and will not agree on the rules based solely on the naive belief that courtesy of human nature will solve these problems. Definitive laws, or rules when it applies, must be placed with known standard priorities, fees and consequences before this will work and before "public" charging will work for all as the market share of said vehicles increases. There must be consistency, just like all things proper in society.
    Trollbait likes this.
