my prius 2010 hatch latch is not locking.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kate f, Jan 23, 2014.
  1. kate f
    kate f New Member
    I cannot lock my prius hatch door. It will shut but the lock does not engage. Apparently the lock is broken. Can I order the part and have a mechanic friend do it for me as Toyota want to charge $200 to install it. The part from Toyota is $210. Anay advice for doing the job cheaper than this?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    A knowledgeable mechanic should be able to install the lock mechanism and save you some money.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved from Prius v to Gen III and from technical to maintenance and troubleshooting.
  4. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Google. You might find the part cheaper or go to a wreckers for a second hand lock. I don't think they'll break too often.;)
  5. Paul G
    Paul G Junior Member
    Baltimore
    I had exactly this problem. I found a replacement lock on eBay for $70 and it took me all of 10 min to install it. Super simple. You just need to loosen 3 10-mm bolts and take off the electric cables and the faulty lock, then put in the replacement lock and fasten everything again.
