Two different types of wheels on 2008 Prius
Discussion in 'Gen 2 Prius Main Forum' started by John House, Jan 25, 2014.
  1. John House
    John House New Member
    I bought a 2008 Prius about two weeks ago. So far I really like it. One thing that puzzles me is that there are two different types of wheels on each side of the car: one a solid allow and the other an allow with a plastic rim around the outer 2-3 inches of circumfrance.
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Did the trim rings simply come off one side? If you pop off the trim rings there is an aluminum rim under em'. Pop off the ones left and see if it's the same as on your other side.
  3. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    Yeah, sounds like the trim rings aren't on on one side.
    SCH-I535
  4. John House
    There are not wheel covers; just that 2 of the wheels have a plastic rim around the outside 2-3 inches; the center of the wheels being metal "spokes" similar to the other 2 solid aluminum wheels. This Prius had Pack # 6. Thanks for trying to help me out!
  5. xliderider
    8,033
    3,211
    Honolulu, HI
    That's exactly what we're trying to tell you. Pull those plastic rings off the wheels and they'll all match.
    SCH-I535
  6. John House
    OK...your are both absolutely correct! Both of the plastic rims came off, and I put them on the right side to make up for getting too close to the curb! I was concerned I might damage my "new" car by trying to pry off something that is permanently fastened. Mystery solved, thanks to you both.
