PIP charging cable won't click into the car
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nathan505, Jan 15, 2014.
  1. bisco
    51,562
    just looked at my ITT L2, no gasket and no place for one.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Well the orange "O" ring in my OEM blue charge handle became partially dislodged again on Friday- so I removed it from the charge handle permanently. Now the handle clicks in and locks properly without forcing it into the car's charge port connector.
  3. bisco
    51,562
    excellent, must be a bit of over engineering.;)
  4. Air_Boss
    Air_Boss Senior Member
    4,169
    1,169
    New Yawk
    That'll void your warranty for sure... ;)
  5. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    It's interesting that some of us have the ring and some don't. I'm one who doesn't, bought PiP late December. o_O
  6. bisco
    51,562
    i wonder if they've eliminated it in production, but it depends on what stock your evse comes out of.
  7. ny_rob
    1,968
    813
    L.I.- NY
    Well I saved the "O" ring in case I do need it for something, but I don't imagine ever installing it in the charge handle again.... seems more trouble than it's worth.
  8. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    And the NSA has already forwarded your deviant behavior to Toyota Collective. Rob, now risk having your PiP confiscated at your next service. :eek: ;)
  9. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    My 2014 doesn't have it, so I assume it was only on early models.
  10. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Nothing clicks for me. The public chargers don't click and my blue OEM L2 upgraded charger doesn't click either. I also have a second L1 charger purchased off of ebay and it rarely clicks as well. The clicking noise happened only on the first year of ownership in 2012.
  11. Air_Boss
    4,169
    1,169
    New Yawk
    Only a one year warranty on the clicks?
  12. bisco
    51,562
    mine still clicks, unless i hold down the button as i slide it in.
    retired4999 likes this.
  13. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Removing the O-ring in the handle FIXED my problem of pushing the charge cable into the PIP.
    It was twisted and kept the handle from seating into the PIP.
    Looks like it's not needed.
  14. CharlesH
    2,796
    1,163
    Roseville, CA
    Just wondering, isn't this issue of the plug not fitting into the car a warranty issue that the dealer would fix for free (assuming we are talking about the OEM plug)?
  15. bisco
    51,562
    someone in another thread did get a new one under warranty. seems a bit silly though, to go thru the hassle when removing the ring solves the problem.
  16. markabele
    5,084
    1,782
    Nebraska
    Unless they give you a new one and you get to keep the old one. ;)
  17. Air_Boss
    4,169
    1,169
    New Yawk
    And BOTH rings!
  18. LesliePIP2013
    LesliePIP2013 Junior Member
    Santa Cruz, CA
    2013 Prius Plug-in
    I
    Both my friend and I have a 2013 and the charger it came with has an orange o-ring. I re positioned it and it seems to be better, but think it will keep moving around. Would be nice to know if it is essential.
  19. mrbigh
    3,686
    699
    Long Island, NY
    It is NOT an essential part for EVSE wand
  20. LesliePIP2013
    Santa Cruz, CA
    2013 Prius Plug-in
    Wonder if we could find out from Toyota if its essential. I called 2 different dealers service dept. One told me to take it out, another didn't really know. He said no part avail so could order a new charger for $300. Yeah right. Anyone try to contact toyota manufacturing to find out if its essential?
