Toyota probing possible heated seat fire hazard...NBC News...
Discussion in 'Fred's House of Pancakes' started by Mike500, Jan 30, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    766
    51,114
    man, we're taking my wife's hycam in monday for the hvac fire hazard, now this. the last hycam had a power window switch fire hazard, this is getting crazy. is it because these things are made in usa?
  3. xliderider
    xliderider Senior Member
    8,054
    3,221
    Honolulu, HI
    This one is due to the materials, not workmanship.
    SCH-I535
  4. bisco
    51,114
    sure, but someone probably scammed them with incorrect documentation.
  5. markabele
    5,084
    1,782
    Nebraska
  6. Mike500
    2,593
    766
    You don't ever get out alive. Everyone born into this world will eventually die.
    If you don't die by fire, it can be from cancer in the fire retardant treatment in the material.
    NRDC: Toxic Chemicals in our Couches
  7. Trollbait
    12,340
    Or Toyota never called to have the materials tested with the seat heaters.
    Or it is actually a part from Japan.
    Friend has a 2005 Camry with a broken moon roof. These roofs break because some plastic rivets snap and the rails get out of alignment. How likely is it that Toyota was scammed out of using metal rivets?
    It is like the lead paint on toys. That was likely because of some corrupt plant manager in China, but it is ultimately Mattel's fault because it is their name on it.
  8. Mike500
    2,593
    766
    I'll forgo the heated seats. Heat causes the chemicals to outgas.
  9. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    No problem.... If my PIP burns I'll dance around the fire cause I'll be getting a brand new one gratis from Toyota now that the info is public record.
