"Temp 72" Warning message flashed on screen 2 seconds
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by davekro, Feb 5, 2014.
  1. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Anyone seen this or know what it is?
    My wife just called to report that a large font message saying "Temp 72" popped up on the dash display for maybe two seconds and then returned to the normal screen. She is driving in mild rolling hills (≈ 100' elevation change max), ambient temp is 38F. Lower grill is blocked about 66%. This has not happened in the 2 months that the 66% grill block has been in place. We have had temps in the high 70's during that time with no warnings.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The warning was probably for 37 deg. That's for black ice on the road. It is above freezing temp but some locations like under the overpasses can freeze.
    Check with her if the message said 37 deg or if she is sure about 72 deg.
  3. bisco
    51,028
    i think when you hit the steering wheel temp control lightly by accident (or on purpose) it flashes the temp on the screen. then, if you press harder, you can change it up or down. i have done this by acciden with my winter gloves on because they press too large an area.
  4. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    or she possible touched the climate control on the steering wheel which shows the selected ac/ heater temprature
  5. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    you typed right before me (y)
  6. bisco
    51,028
    great minds think alike!:p
  7. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
  8. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    It shows the selected cabin temp way up on the dash display? I may have never noticed that. I only noticed cabin temp readings or settings on the lowest green display.
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    yes it does display it on the MFD, but only when you use the steering wheel buttons.
  10. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Thanks guys for the speedy responses. I sent her your answers. I am sure she will feel better knowing 'her baby' did not have a fatal error on her watch! :D
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    My question is completed unrelated to this thread, but how and why is the car going to give a error for black ice?
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Just an informational message popping up on the screen, based on the outside temp. It is not an error message.
  13. markabele
    5,084
    1,782
    Nebraska
    I've never seen that message. Didn't know the car would even alert me. That's cool!
  14. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Its surprising that a prius has this feature and not a RX 450H. I was in lake tahoe and the outside temp according to the car was 12 degrees and the car didn't give a warning or notification of any sort and actual black ice was present on the road.
  15. bisco
    51,028
    my gen II used to have a little snowflake pop up when it got near freezing. i haven't seen anything on the pip so far.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I know Gen2 had that feature. I think I have seen it in my PiP. It pops up like "Low Fuel", if I recall.
  17. Pasaman
    Pasaman Active Member
    289
    111
    Southern California
    I have been driving in 32-45 degree weather everyday since I got my PiP and I've never seen a blackice warning or anything.
  18. retired4999
    2,652
    625
    Eau Claire, Wi.
    Same here!
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Drove back home in 34 deg outside temp. No message so my bad. I miss that feature from gen2.
  20. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    Same here. Not once
    Galaxy S4 ?
