Charging not completed due to charge connector
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pasaman, Feb 5, 2014.
  1. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    I received a message similar to this when I started my car up this morning. I am paraphrasing because I don't remember the exact wording. I had set the timer to charge from 4am-7am and entered my car at 7am to this message and 0 charge. Did I just plug it in correctly or what does this mean? I've never had an issue until today.
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    that usually means the connector was attached but disconnected before the charge was completed
  3. bisco
    51,561
    you can't set the timer from 4-7, so let'd start the analysis from there. are you using the start timer, or the end timer?
  4. Pasaman
    289
    115
    Southern California
    Wouldn't I at least have some charge if this was the case? I had no EV miles to use.
  5. Pasaman
    289
    115
    Southern California
    Sorry let me rephrase. I set the start timer at 4am so it would be done by 7am when I need my car.
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    maybe it was briefly connected that the pin/ lever/ handle got lose
  7. bisco
    51,561
    some people have had problems with the gasket in the bottom of the plug. take a look to see if it has become dislodged.
  8. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    I've found that if you don't push the connector in far enough to get a "click", it will not signal that it's connected, even though it looks like it is.
  9. Pasaman
    289
    115
    Southern California
    I've heard talk of an orange gasket. If you mean this, mine doesn't have one that I can see.
  10. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Toyota really should preform a recall on that gasket, it was really annoying this morning
  11. bisco
    51,561
    right, you've got the '14. have you tried plugging it in to see if it starts charging?
  12. Pasaman
    289
    115
    Southern California
    I didn't have time this morning. It is sounding like it was probably user error. I'll try again after work.
  13. bisco
    51,561
    check to make sure your am/pm is correct as well. some peeps have had that problem as well.
  14. mrbigh
    3,686
    699
    Long Island, NY
    do you remember if the charge inlet indicator light did turn on after you connected the EVSE wand??????????
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    you either set your timer to start at 4 a.m. or you set the timer to stop at 7 a.m. You do not set both timers. I think what happened is the car registered to start charge at 7 a.m. And you un-pluged at 7 a.m. So it gave you a message that it did not charge. Just set your start charge button for 4:00 am and you should be good. :)
  16. Pasaman
    289
    115
    Southern California
    I thought it came on but I may have forgot to check.
    I had it set to start at 4am.
  17. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    PPL w/the older (2012) PIP's have been removing the orange O-ring- the handle then clicks into the charge port on the car properly again. It's a annoying issue- but a simple 10 second permanent no-cost fix that you can do yourself.
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    That's good, and you did not set a stop time? Correct?
  19. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I'm betting you just didn't push the plug in all the way and it never made contact in the port.
  20. Pasaman
    289
    115
    Southern California
    I thought you can't set both? It said Start Time 4am.
    I had previously used stop time 7am but this time I know I selected the 4am start.
