Nuances of a test drive
Discussion in 'Gen 3 Prius Main Forum' started by CapeAnn, Feb 10, 2014.
  1. CapeAnn
    CapeAnn Member
    114
    25
    Northeast United States
    I'll be taking a test drive of a base 2014 Prius sometime during Presidents Week. Aside from the usual checking of mirrors, adjusting seats and what not - are there any nuances I should pay particular attention to when trying it out for the first time? Brake feel, steering feel, sight lines etc. Cheers.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Firstly, here is my 'who should not buy a Prius' post, the Prius is a nice car, but not for everyone.
    considering a Prius | PriusChat
    Then you are on the right track,
    princessprius, cwerdna and CapeAnn like this.
  3. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Can't imagine anyone buying a Prius without a goal of saving money on gasoline. It only takes a first drive to realize the Prius operates and drives like regular car. Avoid fast starts, high speeds, and let the high tech Prius maximize fuel mileage. Enjoy the results.
    CapeAnn likes this.
  4. princessprius
    princessprius Junior Member
    baking in the southwest
    Don't know what you're driving now, but a Prius is a bit different from most other cars.
    I rented one for a bit before I bought my first one, to get familiar with it and make sure it was what I wanted.
    There are buttons to push for different drive modes: electric mode, economy mode, and power mode for when you want it to go fast.
    It also has a push button start and the gear shift experience is different, it's automatic, but the shifter is different than other cars and you push a button for park.
    Light braking helps recharge the battery, and save brake pads.
    You don't need a key to open the driver's door, just have the fob in your pocket.
    Make sure you are okay with the line of sight while backing up, there is a bit of obstruction thru the rear hatch.
    I would also test drive a model three, it has a back up camera which helps with that issue.
    If you find the seats not comfy enough, test drive a model four, much better.
    Good luck, hope you like it!
    spiderman, JimboPalmer and CapeAnn like this.
  5. CapeAnn
    CapeAnn Member
    114
    25
    Thank you for your responses. I've driven all sorts of motorized machines from snow mobiles, to underwater DPV's. However, no hybrid car to date. I have yet to even sit in a moving one to date! I am tempering my expectations as I am considering the Prius for its green qualities and "relative" comfort a highway speeds on the Mass Turnpike.
    I do like the Star Trek look of the thing and the teeny-tiny, blue shift knob. :)
  6. princessprius
    Mine does great on the highway, but stop and go traffic jams kill my mileage, regular city driving is ok.
    Jimbo's post was good, but I didn't have the same issues with running out of gas that he emphasized. maybe the GEN III is different than his GEN II. I got down to flashing a couple times, with zero miles on the odometer that counts down the miles to go before running out of gas, and still made it to the gas station, never ran out.
    I later learned that is bad for it and am more careful now, but had the car for 4 years, 70K miles, no problems.
    BTW, I couldn't find any difference between the 2014 and the 2013, so you may want to consider a still new 2013 instead if you can find one, it would save you about 2K, there's a rebate.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The North American Gen II had a variable sized gas tank that made filling up more problematical than other Prius. My post tends to biased to the Gen II.
  8. princessprius
    That makes sense, good post though - important things to consider. :)
  9. walter Lee
    1,126
    376
    Maryland
    1. 2014 Prius Hatchback base(II) doesn't have it standard but the other versions(III to V) have an integrated backup camera standard. It is a solution for those who find it difficult to see thru the Prius' split rear window arrangement. You & your wife might want to test backing up a Prius with and without a backup camera.
    2. Not sure if you want to test the emergency braking performance of the Prius but.... the Prius has a slight delay when switching from regenerative brakes to hydraulic brakes in a emergency hard braking event - one does not pump(old school) the brakes but instead press on and keep your foot firmly down on the brakes . If the Prius' regenerative brakes are used most of the time - the hydraulic brake pads can last almost the life of the car.
    3. The Prius Vehicle Stablity Control will automatically brake the Prius on in sharp turns at high speed - this may decreases the Prius' MPGs but it keeps the car safe.
    4. The Prius Normal and Power mode button gives the best throttle (accelerator pedal) response and is the mode of choice when driving in hilly terrain, in cold weather, or in a traffic jam. Leave Eco mode for warm driving temperatures in mainly flat driving terrain.
    5. Inspect the exterior paint of the car in the afternoon when daylight is the brightest. Flat black and flat white are the easiest colors to repaint. Exterior paint with metallic specks are the hardest to repaint.
    6. Temperature controls are counter intuitive - you can either turn the heater on via the up and down buttons on the right or the auto button on the left. The defroster requires that air be drawn from the outside.
    7. The air dam under Prius' front bumper has a very low ground clearance - and is easily damaged by potholes and broken-uneven curb-driveway ramps.
    8. If you have a garage(access to an AC outlet) and the driving temperature drops below 32 degrees Fahrenheit for over four weeks per year - consider asking the dealership about installing Toyota's 400W Electric Block Heater - which is used to warm up the engine block to about 60-80F (takes about 30-60 minutes in the morning) - this can improve a Prius' morning commute fuel efficiency.
    9. The dealership will try to sell you floor mats - if you drive in a significant amount of snow and ice - the standard Toyota OE floor mats may not hold out so well - you might consider getting WeatherTech rubber floor mats not just for the driver and passenger area but for the rear cargo bay too. You can buy them from Priuschat's online store too.
    10. Electrical issues. Prius can be jump started but it cannot be used to jump start another vehicle - because it could damage the high voltage battery inverters - so if you need to give someone a jump start - you will need a portable jump starter. In addition to this restriction, the Prius 12Vdc power adapter can only handle about 80w to 100w before its 15amp fuse blows. If you get a power inverter make sure it maxes out at 80w. Most 12VDC portable tire air compressors used draw more than 120W can will blow the 15 amp fuse - to maintain the tire pressure of the Prius yourself consider either portable tire air compressor that has its own power supply OR a 120VAC air compressor.
    11. Nighttime Ergonomics - at night the storage area underneath the transmission stick is not lite up. The Prius night time lighting system isn't really that good.
    12. Sounds of Silence. The electronic transmission is forward for Reverse and backwards for Drive. Feels a bit funny at times - when the Prius is in Reverse it chimes like a garbage truck backup. My car doesn't have it but the newer Prii makes a funny noise when it is driving in all electric mode so vision impair pedestrians can hear it coming down the road.
    CapeAnn and princessprius like this.
  10. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Just drive it and see if you like it. Throttle tip-in is not as aggressive as most other cars so that will likely be the first thing you notice. If you put it in Power Mode, that will help. But you will get used to it in short order and adjust your driving style to suit. Unless you've driven another vehicle with a CVT transmission, that will be the next thing you'll notice. You won't feel any transmission shifts and engine rpm's won't match speed like you're used to. The throttle tip-in is the one thing that still throws me off when I drive another vehicle as I end up snapping my neck a couple times adjusting to the feel of the throttle. One of the things I like about driving a Prius is the smooth take off from a stop, and passengers are always in awe of how silent it is.
    CapeAnn likes this.
  11. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Make sure the seats fit you. A very common complaint among drivers is the uncomfortable seating position and cushion placement especially for tall drivers. The base model will not have electrically adjustable seats and thus makes finding optimum seat position very difficult if you're taller. Some have regretted buying the car after discovering the seats are not what they seemed to be in the test drive.
    CapeAnn likes this.
  12. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Try this:
    1) Get in.
    2) Hold the brake down.
    3) Press the (POWER) button.
    4) Shift into [D]
    5) Drive it like a car.
    If you come at it with the thought of "this is a completely different car" you will miss the point.
    Here are my examples:
    "I just bought a new television; how should I watch 'Game of Thrones' differently?"
    "I just bought a new computer; how should I type my emails differently?"
    "I just bought a new car; do I still have to stop at stoplights?"
    By the time you have finished the test drive, you will know whether you like it or not. Just get in and drive. If you are still uncertain, remember this: the 'go' pedal is on the right, the 'stop' pedal is on the left, and if you turn that big round thing the car changes direction.
    Yeah, I realize I sound really jerkish. Just really trying to stress that you should try to not taint the experience by expecting more, or less, or over-shadowing the experience with too much thought.
    And be sure to follow up with your thoughts and any questions you have. If you end up liking the car, there are multiple lists and threads dealing with purchasing a Prius. Even if you fall head-over-heels in love with the car, be sure to come back here and go through those threads BEFORE purchasing.
  13. GBC_Texas_Prius
    218
    gbc texas
    I own a 2010. If I were test driving a newer model, I would test the brakes in a situation where one front wheel is going over a raise like a speed bump or one wheel is dropping in to a indentation like a pot hole. Just to see if the brakes give me the willies like my 2010 does. It wouldn't be an issue with me, just like to know if it is different. I've learned to avoid such braking situations if possible.
  14. CapeAnn
    CapeAnn Member
    114
    25
    Thanks for your feedback regarding nuances of the Prius Gen III (base model) and timely considerations when I take a test drive. Very helpful info. as I seriously consider the Prius as a long-distance traveler. I have no real expectations of the Prius other than it safely gets me from one place to another. With all the feedback - I can hardly wait to try the brakes, push the Power/Eco buttons!
    Cheers,
    Cape Ann
  15. CapeAnn
    CapeAnn Member
    114
    25
    I think I might take a hard corner on the 2014 test drive? Love to see the salesperson's reaction. :) This question is motivated by seeing Prius accessories like lowering springs and anti sway bar. Just wondering how "squidgy" it is on corners at at highway speeds.
    Cheers
  16. ETC(SS)
    7,172
    ^ Why not just rent one for a weekend?
    The G3 is a great commuter car, and let's face it.
    Driving on a turnpike is just what a one speed hatchback with electro-lux steering is built for. :)
    However (comma!) it's going to take more than a ten minute test flight with some under-informed sales associate slobbering in the co-pilot's seat to discover whether or not you want to put 300,000 miles on the odometer.
    Me?
    I like cars.
    They're more than just a transportation appliance to me, and I generally keep them for a decade so I'm going to research a purchase decision a little differently than somebody who could give a rats about visors that don't extend, and "Hellen Keller" radio systems, and noisemakers on the inside of the car that screech at you when you put the car into reverse.
    Every car has its strengths and weaknesses, and as Tony stated above, driving one is pretty much driving them all if all you want to do is get to work and back.
    Many of the Priuses weaknesses are quickly ameliorated by $29 fill-ups that will give you 500+ miles. :)
    Oh...and if you live in the frozen North?
    The G3 can make for a great backup power supply for your home if you lose electricity for a week during a winter snow storm! :D
    jhinsc and CapeAnn like this.
  17. BZzap!
    BZzap! Senior Member
    1,607
    878
    My first impression was the total lack of steering feedback. The Prius' electric steering system is quite uninformative. After owning one however, it becomes a non issue. Great car!!!
    retired4999, jhinsc and CapeAnn like this.
  18. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    This is totally on point, and describes our experience test driving a used 2010 that we wound up buying.
    It's a car you fillup with gas that gets great mileage. And it's got cool hybrid tech inside.
  19. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) Fuel efficiency was my primary consideration, which hasn't compromised any known weaknesses for me.
    CapeAnn likes this.
  20. CapeAnn
    CapeAnn Member
    114
    25
    Thanks again folks. Mileage and being Green are the biggest considerations for me. As I guy who has driven large trucks, AWD's, snow mobiles, underwater scooters, mopeds, motorcycles and carbon race bikes - I am used to different. I will keep in mind your observations / recommendations when I take a test drive shortly. It'll be a treat....unless the salesperson "slobbers" in my lap. :D
    Have a great day - CapeAnn/North Shore of Massachusetts
