Question on Electric Power Steering, i have no steering assist.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LT1, Mar 6, 2013.
  1. LT1
    LT1 Junior Member
    2006 Prius, I lost all steering assist. I did a lot of research came to the conclution its the EPS ECU failed.
    Feels like no power steering.
    No DTC.
    I see PS on the display and red triangle.
    Is there a write up anywhere online to replace the
    EPS ECU, i kept searching and couldnt find so im gonna be going at it, " in the dark" hope i dont break anything while replacing it.
  2. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Better see your dealer first.
  3. Patrick Wong
    18,200
    6,490
    You can find repair manual info at techinfo.toyota.com
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    How did you check for the no DTC condition? If there is a major malfunction, and an indicator on the dash, then some DTC would possibly be set. A generic scanner won't read the Prius specific PS ECU codes.
    However, if there really are no DTC, then that means that the 12VDC to the ECU has failed. If the ECU has developed a short, it should blow a fuse, probably the EPS fuse.
    The PS ECU is located above the steering column. You have to dismantle the driver side dash to get at it, search for those instructions here. Otherwise, it is a plug-in affair, so not a problem to change.
  5. LT1
    LT1 Junior Member
    Thanks a lot for the responses, i found where it is and ordered EPS ECU on ebay for $40 and replaced it myself and it works excellent!
    Now my only question is, since it turns perfect do i still have to get steering calibration done from the dealer?
  6. LT1
    LT1 Junior Member
    nh70 : i used a basic code reader by "actron". I didnt get any DTC's with it when it failed.
  7. nh7o
    1,686
    340
    Hawaii
    Well done, glad to hear that it turned out to be a simple fix. That code reader you used likely only reads the generic engine related PID's, and won't read any of the other ECU's in the Prius. If you want a Prius code reader, look for "mini VCI" on eBay.
    I would expect that if you have no driveability issues, and the steering wheel is centered, then nothing more is required as to calibration. If you end up having the steering column replacement safety recall done, the dealer will do that step anyway, or at least should do so. Congratulate yourself for having saved many $$$ over the dealer's price.
  8. glpss
    glpss Junior Member
    Northeast PA
    I had the same problem with my '06 Prius. No power steering, the red triangle with the exclamation, and P/S on the display. I went into diagnostic mode, took pictures of the codes under the different menu options in case I needed them, and cleared all the codes. Turned it back off, and when I started it, the power steering worked. I only used it for a day since, but so far so good. No parts needed.
  9. nh7o
    1,686
    340
    Hawaii
    I would say that it is too soon for certainty. Failure mode for any electronics certainly includes intermittancy, so if the problem returns some day, we will not be surprised. Not a difficult fix, if it is a similar ECU replacement.
    Note that those diagnostic mode displays are of no real use in troubleshooting.
  10. Rich12
    Rich12 Member
    176
    29
    No they won't; they'll screw up your perfect steering like they did mine and everyone else who has had the recall shaft done. It results in the dreaded 5 degree off center syndrome.
  11. nh7o
    1,686
    340
    Hawaii
    It can't be all that bad. Mine came out of the dealer perfectly aligned.
  12. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I guess I am unlike "everyone else". I had the steering recall done and the steering wheel was dead center when I got it back. When I took it in, it was off about 2 degrees. Now perfectly flat.
  13. glpss
    glpss Junior Member
    Northeast PA
    As an update, it has been five weeks and my power steering has still been working perfectly. All I did was clear the codes through the diagnostic screen.
