Charging stops for 10 seconds
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CaliforniaBear, Feb 16, 2014.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Intermittently, about every 10 to 30 minutes the charging stops for about 10 seconds. I don't think that's a problem. I'm wondering what the reason would be.
    How do I know this... I have a HAN (Home Area Network) device that reads the net electricity energy in/out every 10 seconds. When everything is quiet energy-wise you can easily see when you turn on/off a 40 watt light. The report is to the nearest watt, the accuracy is whatever the meter provides. The PiP draws about 1430 watts from my 120 volt line.
  2. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    Building in automatic self-checks into software is a common practice. It wouldn't surprise me at all for the charger to include that, especially considering the task it is fulfilling.
    Kudos for being so observant.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    I don't remember who, but someone here had printed charts showing charging cycles, that showed what you are talking about, the ups and downs, and short no charges. I am sure they will pipe in at some point. So nothing to worry about at all, I'm sure.
    Maybe you can search and find it here. I know trying to find by search is kind of hard. good luck.
  4. john1701a
    12,805
    5,291
    57
    For the battery itself, there are some conditioning events we know little about. Discovering them and uncovering details is what contributes to our strong support for Toyota. It confirms how well they did their homework on longevity.
    Sadly though, when a update is derived, it is quickly given the label of "recall" instead of being regarded as proactive effort.
    retired4999 likes this.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yup, me, I had charts from my data logger showing that the charger drops to zero amps eight times during my two hour and 34 minute charge.:cool:
    retired4999 and john1701a like this.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thank you! (y)
    priuskitty likes this.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    :D
  8. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    In order to check the SOC, the charging has to be stopped. Interesting that the charging current drops near the end.
  9. bisco
    51,561
    i think it was priuskitty.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y)
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    and how do you know that?:whistle:
  12. bisco
    51,561
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I had a thread called "Attention Kill A Watt Nerds" with the charts, but alias, the charts are no longer there.:cry: :notworthy: :sick:
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Thank you very much, (Elvis)
    SGH-M919 ? 4
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Could be, I don't know, just stuck in my head, lol
    SGH-M919 ? 4
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Long live the king! :)
  20. CharlesH
    2,796
    1,163
    Roseville, CA
    That is how the charging cycle is supposed to work for lithium-ion batteries. Cell phone chargers behave the same way.
