Switching to LEDs - anything to watch out for?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gouda Cheez, Feb 1, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Watch out for SMD LEDs in the parking bulb spots however. I had some get too hot there and burn up, leaving a smoke film on the inside of my headlight assemblies.
  2. Gouda Cheez
    Gouda Cheez Junior Member
    73
    Good to know!
  3. mediahound
    903
    155
  4. GAM
    GAM Australian Prius Owner
    Australia
    I had an issue with mine. When I replaced the parking lights with LED's I notice that whenever I went in to my work carpark, I lost radio signal and got static. Turned out that my parkers were turning on automatically and introducing static. It was not noticeable when I had good signal strength but with lower signal in the car park is took the radio out completely. Turned lights off and problem went away. The problem also occurred with the interior lights on LED but not as noticable as usually the car radio is off before you open a door.
    Put original bulbs back in and no probs.
  5. Air_Boss
    Air_Boss Senior Member
    4,161
    1,166
    New Yawk
  6. Gouda Cheez
    73
    So far I've gone with white LED's for the license plate bulbs and that's it. May do more LED's down the road, but I'm very happy with just the plate lights so far.
  7. Gouda Cheez
    73
    Forgot to mention... for parking lights I went with a regular 168 amber bulb. For whatever reason I like the egg yolk look.
  8. mediahound
    903
    155
    Try these, they're cool:
    PIAA 19173 168 Plasma Ion Yellow Wedge Bulb - 2 Piece : Amazon.com : Automotive
    from
    Review: PIAA Plasma Ion Yellow 12v/5w 168 wedge bulbs | Balancing Act
    However, I've never understood why people put LEDs on their license plate though. I guess if you have a personalized plate it makes sense, but it just makes it easier for the cops to read your plate...
  9. Gouda Cheez
    73
    I drive a Prius for MPG's... not too worried about cops looking at my plate. :) I put white LED's in the plate lights of all cars I own. Don't know why... just like how clean they look.
    I love the orange in the parking light vs. the yellow.
  10. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    Marc, I just noticed your question. I switched my PiP a while ago to a kit sold by ExLEDUSA, suggested by another thread on PriusChat. You get to pick your colors (I picked blue). Easy install and they work great. Good instructions on their web site on how to choose and how to install.
  11. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    thanks... hows the blocker working?
  12. DadofHedgehog
    681
    282
    northern Virginia
    Awesome - keeps me warm ;)
  13. pauerbach
    pauerbach Member
    101
    34
    I switched all the interior lights to LEDs, but started blowing the same fuse over and over. So much for a lower power consumption...
  14. mediahound
    903
    155
    Probably a short, rather then a power issue.
  15. pauerbach
    pauerbach Member
    101
    34
    So how might I remedy this? I'm not electrically inclined haha!
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Which fuse is blowing?
    VS980 4G ?
  17. mrbigh
    3,686
    699
    Long Island, NY
    lets start from the beginning, you have to identify in witch circuit the fuse blew.
  18. pauerbach
    pauerbach Member
    101
    34
    It's the 10 amp fuse for the interior lights: map lights, dome lights, puddle lights, etc.
  19. xliderider
    xliderider Senior Member
    8,129
    3,266
    Honolulu, HI
    When you replaced the bulbs with LEDs, did you have a hard time removing and reinstalling any of the bulb holders/harnesses?
    It might be possible that you pinched a wire against a sharp sheetmetal edge when reinstalling everything. Now you have a short circuit to ground (car body) that's causing your fuse to blow.
    SCH-I535
  20. Joele3
    Joele3 Active Member
    135
    200
    Bay Area
    I've read on a different posting that there were issues with the TPMS light and LEDs in the license plate postion. Well I have a 2010 and it took roughly 2 weeks for that same issue to show up. I used ebay LEDs . I've been driving with the light coming on and off. I may just put back the factory bulbs or I may try another manufacturer.
