My DIY $17 Prius cargo liner made from recycled plastic bottles...
Discussion in 'Gen 3 Prius Main Forum' started by eddiehaskell, Feb 18, 2014.
  1. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    I was looking to buy a cargo mat, but of course none of them fit quite right and the ones that did fit (Husky, Weathertech, OEM) were expensive ($100+) and did not cover the backseats when folded down.
    My original plan was to follow another thread on here that mentioned using indoor/outdoor door mats but it required cutting and buying waterproof tape/glue to assemble it in the right shape (still didn't cover the backseats). However, while I was at Lowes, I saw something called the Ecorug that was 6x8 and only $17. It says the polyester fibers are made from 100% post-consumer recycled bottles. That set off a light bulb...hey, this will cover everything with no tape, glue or seems!
    I trimmed it down and intentionally left it a little big to protect the plastic from anything with sharp edges. I even had enough left over to make a mat that runs under the legs of my recliner!
    It just happens to be almost an exact match to the factory carpet...
  2. xliderider
    xliderider Senior Member
    8,054
    3,221
    Honolulu, HI
    Looks great. (y)
    What do you do when the seats are up? Fold the rug I suppose? Pics?
    SCH-I535
  3. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    Thanks. Yes, fold it back and roll toward the front of the car. Here are a few pics:
    Manny210, WE0H and BluetoothEdsel like this.
  4. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    BTW - this only took me about 30 minutes. Just take out the removable cargo parts and sorta trace it onto the back of the carpet. My tracing was about 2" bigger all around. I then put it in and started hacking off parts that I didn't want. Be careful to not cut the seat belt when trimming around that area!
  5. xliderider
    8,054
    3,221
    Honolulu, HI
    Looks better than the mover's blanket I have back there. :p
    The same Eco-rug in my area Lowes is $20. Might have to check it out.
    SCH-I535
  6. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    It's $17.97 in-store here. I used a 10% coupon that made it around $16. :)
  7. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Great idea, I like the way it covers the seat backs when they're folded, and not in the way when seats are up.(y)
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    Looks nice! good job! :)
  9. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    That really is a great idea. And you cut it to fit perfectly. Nice :)
  10. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Not gonna lie, I'm a little let down that it's just recycled carpeting. I was expecting some crazy DIY experiment.
  11. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Very nice. I hope Home Depot has it because there is no Lowe's out here.
  12. xliderider
    8,054
    3,221
    Honolulu, HI
    WE0H and lumpy95 like this.
  13. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
  14. Mendel Leisk
    40,556
    A problem with the Toyota and aftermarket mats/trays is they don't cover the area when seats are flipped down, your's does, and looks good.
    We just throw an old blanket in there, tucked under the rear lip of the floor panel. Big enough to mostly cover the rear seat backs if they're flipped down. But your's looks a lot classier, LOL.
  15. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    That's what I have been doing also in my Gen 2 and in my Gen 3. The mat looks a heck of a lot cleaner.
  16. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Great find. Gonna have to check this out see if it's long enough to cover my v cargo area. I too use an old moving blanket right now but when loading/unloading my bikes in the back the pedal grabs the blanket and shifts it around! This looks more form fitting and presumably stays in place much better when loading cargo?
  17. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Well done. Certainly glad you're sharing with the community since cargo liners is something most people are interested in.
  18. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    I made a couple of mats for our Honda Fits using this same material. Our Lowes had it in the floor covering department on big rolls. You could measure out and purchase just what you needed. Just keep in mind that while this will protect from dust, debris and such - it is NOT water proof !
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    LOL!
    I made a rear seat well mat out of that same material for my Honda Fit....
    It worked great and was very durable.
    The only reason I spent more and did NOT do this with the Prius, was that especially in the rear hatch area, with the Hybrid Battery present I felt keeping the area as water proof as possible was a potentially important issue.
    So I bought The Weather Tech cargo Liner.
    It however doesn't cover the back of the seats when they are up....
    Some weekend I might make a liner like this and use it in conjunction with my weathertech liner...
  20. jdenenberg
    jdenenberg EE Professor
    3,924
    1,922
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That's a job for Scotch Brite (or Shoe waterproofing).
    JeffD
    vvillovv likes this.
