Removing charge port door
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Electric Charge, May 11, 2013.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Does anyone know how to remove the painted door (not the plastic arm holding this door) which covers the J1772 inlet? It looks like it might be a matter of prying a plastic clip, but wanted to make sure before I attempt this.
  2. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
    I'm fairly certain that it is glued on. May I ask why you would like to remove the door?
  3. Electric Charge
    545
    133
    Syracuse, NY
    I'd like to wrap it, thought it would make it a little easier, as it looks like it's just a clip, but if it's glued on, I'll just try to do it without removing the door.
    Thank you for taking the time to respond, appreciate it!
  4. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
    Hey, no problem. Post the results of your wrapped door if you ever get around to doing that!
  5. thx123
    thx123 Junior Member
    CA, USA
    2014 Prius Plug-in
    Have you figured out how to remove the charge port door panel?
    If you how hard was it?
