I had the same problem with looking for the 2011 prius manual. I googled "2011 toyota prius owners manual" and the top result was toyota.com manual section. The manual was broken into 37 separate pdf docs instead of 1 big one, pretty annoying. I opened each one individually and saved each one into a folder. The docs all saved in order, so instead of opening up 1 big file I open up the first one and read it to the end and the second one will start where the first one left off.
