Wish list for next generation Prius Plug-in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 100 mph, Mar 7, 2014.
  1. 100 mph
    100 mph Junior Member
    40
    Here is my wish list for the next generation Prius Plug-in:
    1. Greater pure electric mode range (c'mon Toyota, you can do better than 13 miles)
    2. When you floor the accelerator in electric mode, it doesn't go into hybrid operation
    3. Reliability that matches the non-plug-in Prius
    4. With lithium-ion traction batteries anticipated for the regular Prius, the cost of Plug-in battery replacement goes down
    5. It keeps its single-occupant HOV access status.
  2. Emcguy
    Emcguy Member
    176
    29
    Australia
    1. PiP release in Australia.
    2. Less of a price jump to purchase the PiP option. The increase on the US cars hardly seems worth it (excluding rebates)
  3. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    what about adding a spare tire, I'm sure the weight of ~40lb tire won't kill the range.
    Mul, JacksonMs and Mendel Leisk like this.
  4. 3PriusMike
    3,095
    2,417
    Silicon Valley
    Of course almost everyone wants this. But there is no magic. It will cost more. It will take up more cargo space. It will make the car heavier reducing both EV and HV efficiency
    Yes, this is a good idea.But then there is the other side of the equation...when you really floor it aren't you asking the car to accelerate as fast as it can? Why wouldn't you want it to use all propulsion means available to do this?
    Is there a noted difference?
    Sure
    Sure, but the CA stickers will be long gone before a new PIP ships.
    Mike
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Well, Barry White sang, ..."it's not enough, it's not enough, Elvis..."If I could dream..., and Andrea True had a song in the early 70s, "More, More, More".
    What I want is a Toyota PIP with 40 mile EV range. I'll accept some trade offs. What I don't want is a pure EV, or a Volt.
    JacksonMs and DianneWhitmire like this.
  6. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    Just give me 6 more MPH speed to 70 in EV.
  7. inferno
    inferno Senior Member
    1,072
    405
    • More EV power (for certain, maybe 70 MPG)
    • More EV range (I'm certain this will happen - if today's measured at 11 miles ev, we should see 20 or 21)
    • Next Gen Gas efficiency (duh this will happen, probably more on the lines of 54mpg average than 55 mpg)
    • Spare (might or might not happen)
    • Larger and larger trunk (I'm certain this will happen, but not more than 10% increase)
    • Cheaper (no, I think it'll be the same price or slightly cheaper. The new engine will be cheaper, supplies cheaper, but that's how tech works, better bigger badder but same price, at least until incentives run out...but the incentives are supposed to spark higher supplies - which will happen as Tesla is pushing for that megafactory for battiers)
    • Better interior - subjective but sure, it will be different
    • Better exterior - subjective but sure, it will be different, I'd say 20% different, if Gen 2 to Gen III was a 20% difference in exterior, I'd wager the same diff
    • Sunroof - I bet there would be a model with this a year or two after release
    • AWD - No I don't think this will happen, but there will be a plugin hybrid that has that later...
    • Did I miss anything? :p
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Run the fan to de-fog (not de-frost) the windshield without starting the ICE. Example: this morning it started to fog, opening the window part way made it go away. The fan would do that nicely without the ICE running.
    DadofHedgehog and inferno like this.
  9. bisco
    51,276
    i would like one in orange.
    Greenwave and -Rozi- like this.
  10. SJ PiP
    SJ PiP Member
    190
    35
    HV/EV control on the steering wheel
    Hi Burrito!, Sanjath and rogerv like this.
  11. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    I second that!
    DianneWhitmire, JEP and inferno like this.
  12. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Yeah, the console switch is too close to the Park button. I use that a lot more than I use the one to go from EV to HV, so I have to look down sometimes to make sure I hit the right one.
    Hi Burrito! and Sanjath like this.
  13. CharlesH
    2,796
    1,163
    Roseville, CA
    Like by this summer, at the rate they are going.:( This is not something the auto manufacturers can do anything about, as the limit on plug-in hybrid (green) decals is written into state law.
  14. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    How about more interior colors besides gray? Why can't I have tan?
    JacksonMs likes this.
  15. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    From a parts guy perspective: Be careful what you wish for. Some of the older Toyota and Lexus vehicles had tan, gray, blue, black interiors. Over time, spare parts run out, and everything supersedes to black. Now you have a tan interior car with one black seatbelt, door handle, etc.
  16. kriggleman
    kriggleman Junior Member
    Indianapolis, IN
    You can already do that. You just have to set the temp to LO before the car is fully on. (Push start without foot on brake, turn on fan and change temp to LO).
    Definitely agree with need for a way to disable heat mode before turning on the fan (while car is running) to guarantee ICE won't start purely because of fan.
    I vote for electric defrost. I think that's one of biggest missing pieces that isn't that hard to fix.
    Finally, in EV mode and cold exterior temps, why am I forced to blow cold air at my feet just to defrost the window???
    mxben likes this.
  17. CaliforniaBear
    1,179
    289
    Northern California
    Oh... I didn't know that. Thanks!!
  18. bisco
    51,276
    shifter to the steering wheel and cup/phone holder where the shiter is.
  19. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    That would create the issue of accidental touches
    iPhone ?
  20. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Accidentally touching what?
