Replace or Cut Rotors:
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HiccaBurp, Mar 10, 2014.
  1. HiccaBurp
    HiccaBurp Junior Member
    49
    Vernon Hills, IL
    I'm at 140,000 mi. I replaced the break pads around 120k, but did not replace/cut the front rotors. I'm in the process of replacing my wheel bearings.
    1. Should I cut the rotors for $20 a piece? Or replace?
    2. If replace, which brand? I see the wear ever brand at Advance auto parts is like $37 + tax. Beck Anley is around $72. Which brand came with the car? Or get from Toyota with discount(friend works there)
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    I vote for cutting.
  3. JC91006
    JC91006 Senior Member
    16,656
    8,506
    I wouldn't do anything to the brake rotors unless you are having brake issues. With the pads having been worn 20k miles, resurfacing or replacing the rotors now may not be the best thing to do. You would have to mesh the old 20k brake pad surface to the new rotors or buy new brake pads to avoid doing this.
    But once again, if there are no braking issues, I wouldn't mess with resurfacing the rotors. They are normally done the same time as brake pad changes, not when the pad already has 20k miles on them.
  4. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    If nothing wrong them, leave as is. If the have a lip and might be warped, I'd replace with OE Toyota discs. You will probably get another 100k plus out of them
  5. HiccaBurp
    49
    Vernon Hills, IL
    I replaced my pads because they were at the squeal marks and my wife was getting ready to go on a road trip to Colorado. I did the pads late evening the day before she left and no places were open to cut the rotors. I didn't think replacing was needed since they looked good and felt true.
    I'm cutting them now as I think I lost some physical braking(low speed when they kick in). They just don't grab as well as they use to. Hopefully the pads will reseat themselves to the newly cut rotors. I'll let you guys know how it goes..
  6. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Be aware the minimum safe thickness for the front rotors is 19 mm ( 3/4 inch ) after machining. You must then have some extra thickness to allow for future ware.
    John (Britprius)
  7. HiccaBurp
    49
    Vernon Hills, IL
    Thanks John! I will measure them when I get them back. The shop I use usually checks for min specs and if at/near minimum, they won't send them back out nor charge me.
    If too close for comfort, I'll have my friend at Toyota pick me up a couple new rotors.
    usnavystgc likes this.
  8. JC91006
    16,656
    8,506
    If safety is an issue/concern, you should just buy another set of pads and install them with your new resurfaced rotors. It's $50 peace of mind.
  9. HiccaBurp
    49
    Vernon Hills, IL
    JC,
    On our chevy 3500 vans, the rotors warp often(bad design). Number of times we've had to resurface/replace rotors with existing pads without issues. I will try the same with the Prius.. if any doubt, I'll purchase new pads. I'd have to wait till tomorrow evening if I wanted new pads now.
    Thank you!
  10. JC91006
    16,656
    8,506
    I believe John (Britprius) did the same, just resurfaced the rotors using the old pads. I don't think he had any issues with it. But like you mentioned, they have to reseat properly for the most effective braking.
  11. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Replaced front pads and rotors on my 2005 Prius in 2010. ALL Advance Auto replacements (not cheap) using ceramic pads. Needless to say, 3.5 years later, the metal on the contact surface of the rotor began flaking off in chunks! Yes, you read that right! It seems as though the rotor is fabricated with bonded metals. When the rotors were removed, the outer metal contact surface could be peeled away exposing a smooth but rusted core. NEVER again, using aftermarket parts on ANY of my Toyotas! Lucky for me, both the rotors and pads had a lifetime warranty against wear and I received a 100% refund from Advance. Replaced everything with OEM pads and the ORIGINAL rotors that I had resurfaced and stored away back in 2010!!
  12. HiccaBurp
    49
    Vernon Hills, IL
    Wheel bearings in and noise gone :) Rotors resurfaced and still well over minimum thickness(.835 in). Took it out for a test ride and the breaks feel much better now. I will keep my senses open for any funny breaking issues. Should be GTG!
    Priusyippe.. glad you kept the old rotors! If they still have enough meat on them.. see no issue. And that was my concern with buying APP/AZ/O'Rilleys.. the cheap stuff they have, well.. it's cheap! And the more expensive/special order is as much as factory so why bother.
    Gorilla97 likes this.
  13. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    Here's to hoping you don't have any breaking issues, because that would be bad. ;)
    SCH-I535
  14. JC91006
    16,656
    8,506
    breaking Brakes.
  15. unterhausen
    unterhausen Junior Member
    64
    State College, PA
    my lathe was used for many years to cut/grind rotors. Poor thing. The time I saw the auto parts guy cut them on one of the specialty lathes, he took an extra heavy cut. Seemed like a waste.
    I haven't had reason to think about replacing the rotors, but I guess if I get it back on the road after the transaxle I should start thinking about replacing everything
  16. Gorilla97
    Gorilla97 Junior Member
    110
    Edmond, OK
    I think my front driver side wheel bearing is going out. Did you replace yourself? If so how difficult was it to do?
  17. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I'm a little late to this discussion but........
    You should do neither unless there is some definite indication that there is a problem
    with the present rotors.
    That said, I'm not a big fan of turning rotors.
    I've had it done a few times over the years and it seems like it is only a temporary fix.
    So if there IS a problem indicated, I vote for replacement.
  18. JC91006
    16,656
    8,506
    Why do you prefer replacement over resurfacing? Also how is replacement a more permanent fix vs resurfacing a temporary one?
  19. Easy Rider
    982
    210
    N. Central Florida
    Because of experience.
    Most of the time, I have turned rotors because of un-even stopping; a pulsating pedal or jerky feel.
    I think by the time that happens, the base metal of the rotor is damaged and a new surface only lasts a few thousand miles.......if that.
    IF the only problem was some uneven scratches because you let the pads go too long.......then maybe turn them.
    But in every case, new rotors should last longer than turned ones.
    Overall I think it is a waste of money, especially is you are paying someone else the labor charges.
  20. JC91006
    16,656
    8,506
    There was another thread just the other day, someone had replaced their rotors and it didn't quite perform as good as the original OEM rotors that were replaced. Luckily they still had the original OEM rotors, resurfaced the original OEM ones and put them back on the car, they seemed much better than the new replacements.
    In my personal experience, I didn't find any difference after resurfacing a rotor. They performed like a new rotor. If there was very little cost difference between new and resurfacing, I would go new. If the replacements were very expensive, then I would resurface to save money.
