Protective cap for exposed electrical connections under hood?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Robert Holt, Mar 11, 2014.
  1. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Was under hood adjusting headlights and noticed that this set of connections is exposed whereas all other connections were nicely sealed or at least protected with plastic shields. Has anyone made or purchased a plastic dust/moisture shield for this junction block, something like the plastic shield on the rear set of connections? Given salt spray in winter I just am uncomfortable with salt water getting in those thin wire connections over the long run. Thanks in advance for ideas. image.jpg
  2. Mike500
    Mike500 Senior Member
    2,593
    766
  3. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I was wondering what your post was about. The pic of the cover itself left me confused. I thought it was for the OBDII connection.
  4. Mike500
    2,593
    766
    It is the connector on the driver's side inside the engine compartment between the air filter housing and the inverter.
  5. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    question is where one can buy the new cover?
    BION
    STARCALLER
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I found one listed on Ebay for $35.
  7. StarCaller
    1,271
    723
    how you know if it's the new or old version?
    BION
    STARCALLER
  8. StarCaller
    1,271
    723
    ordered one. :)
    BION
    STARCALLER
  9. Mike500
    2,593
    766
    The new version has removal tabs shown the photo.
    I've circled the removal tabs in RED.
  10. CTitanic
    CTitanic Member
    153
    South Florida, FL, US
    Here is another picture of these wires without cover.
  11. StarCaller
    1,271
    723
    before & after/
    Burna J likes this.
  12. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    Overpriced piece of plastic, IMO. Should only be a few bucks.
    SCH-I535
  13. CTitanic
    CTitanic Member
    153
    Agree. Very overpriced.
  14. Mike500
    2,593
    766
    I'd have to agree. If you were to design the cover, fabricate the injection mold for this item, and had one made, it would be around $30,000 plus.
    If I had to buy it once, compared to purchasing the wiring harness or repairing the pigtail, which would never be the same as an original one, it is worth it just as a cheap insurance policy.
    It's like saying that a $20,000 Rolex watch is worth no more than the commodity value of 8 ounces of brass, industrial diamonds, jewels, or other materials.
  15. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    My question is why should we have to buy a cover in the first place?
    Obviously, something is missing. The connector above it is covered.
    I noticed this on my 2011 Prius and was surprised to see it was not corrected on the newer models.
    It bothers me, but not $35 worth enough to fix it. Maybe their research has determined that leaving it exposed did not create enough problems or cost to be remediated by spending the extra 50 cents in plastic to cover it. But someone made a plastic cover to correct this deficiency, so we are not alone in our concerns. Problems or not, it does look cheap - like when I looked at a $35,000 Chrysler 300 and the trunk had no carpeting.
  16. gliderman
    gliderman Active Member
    751
    225
    IF it was necessary for that electrical box to be covered, Toyota would have covered it. It's just more bling.
    I do think it is a good idea, like the rear bumper cover. But at $35, it is way overpriced. If it were closer to $6 I would consider it.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Can't default to that thinking.
    I mean, it might not be "necessary" and obviously isn't immediately necessary, but I can't help but think that over the course of years having those wires covered would be a lot better than uncovered.
    One sneaky rodent with a penchant for brightly covered wires could instantly make the absence of a cover for those wires a missed commodity.
    Mike500 likes this.
  18. Mike500
    2,593
    766
    Same logic would conclude that, "If man was meant to fly, God would have equipped him with wings."
    Or, GM knew what they were doing, when they designed the ignition switch for the 2005 Chevrolet Cobalt.
  19. gliderman
    751
    225
    Its the same logic that some of you use when a person suggests a different oil, filter, or light bulb or anything that is not OEM Toyota in USA. Oh, the irony! (LOL!)
  20. Burna J
    1,066
    3,335
    53
    Long Beach, CA.
    The someone you are talking about, is Toyota. They're JDM.
    Here's the other covers that we don't get here in the States.
    Little pricey, but they look great on...IMO.
