Oil Consumption
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Frank06, Sep 5, 2011.
  1. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I do agree the pricing is very erratic, especially for the complete engine. Anyone with good skills could easily build up a practically new engine complete for less than 3 to 4K in my book. But that is what they show.
    Merkey likes this.
  2. theshark
    theshark Member
    164
    Martinsburg, WV
    Changed oil last Friday.. Added a quart last night.....*sigh*
    Debt is dumb; cash is king ...and the paid off home mortgage has taken the place of the BMW as the status symbol of choice.
  3. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I was just looking at my excel sheet I keep. It seems almost like clockwork - every 3,000 miles Im having to add 1/4 quart of oil. I have 79,000 miles right now.
    Compared to what I have read on the site, Ill take it. Not looking forward to adding quart(s) of oil between oil changes, once my mileage gets up there. And the oil burning issue sounds to be not one of those "if" things, but "when". :mad:
  4. uart
    uart Senior Member
    4,220
    1,210
    Australia
    Hi PriusGuy. I'm currently just over 125k miles (203000 km) and my oil consumption is fairly similar. Mine is about a quarter of a liter every 2500 miles, and it's also like clockwork. I often joke that if my odo stopped working I could still log my mileage by just looking at the dipstick. :LOL:
    BTW. Mine doesn't seem to have increased much in the last few years. :)
  5. theshark
    theshark Member
    164
    Martinsburg, WV
    Now I'm adding a quart every week about 679 miles...
  6. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Go and get some "seafoam" and add to your oil. Seafoam works like MMO, mentioned on other post, but I think it works a bit faster. Are you using 5w-30 oil?
  7. theshark
    theshark Member
    164
    Martinsburg, WV
    Yes, 5w-30
  8. JC91006
    16,761
    8,562
    the amount of oil you are burning, you are probably going to need a new engine soon. The seafoam "may" help a little (meaning from 1qt/679 mi to possibly 1qt/1000 or 1200 mi), but getting another engine is probably in your near future.
  9. theshark
    theshark Member
    164
    Martinsburg, WV
    No new engine. I will trade it first.
  10. theshark
    theshark Member
    164
    Martinsburg, WV
    No new engine for this car.. I'll trade it first.
  11. JC91006
    16,761
    8,562
    If that's the case, add seafoam and keep adding oil when needed. When you get people looking at you funny from all the smog you are blowing out the back.....time to trade it in.
  12. theshark
    theshark Member
    164
    Martinsburg, WV
    Funny thing is, there is no blue smoke coming from the tail pipe (exhaust) No oil leaks (checked several times by mechanics)
    I was told the Catalytic converter is most likely catching it all, and will fail very soon at this rate...
  13. JC91006
    16,761
    8,562
    change the pcv valve?
  14. theshark
    theshark Member
    164
    Martinsburg, WV
    Been there done that.. several times i might ad, last change was 2 months ago...
  15. JC91006
    16,761
    8,562
    Try the seafoam and let us know if there's improvement. A local hybrid shop owner tried it on his customer's cars and it showed a lot of improvement.
  16. theshark
    theshark Member
    164
    Martinsburg, WV
    Will do, thanks
  17. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Don't use seafoam. If you don't want to swap out the engine, then sell your car as is while it still runs.
    Why risk making the problem worse. Unless you want a 3000 lb paperweight.
  18. JC91006
    16,761
    8,562
    What's wrong with seafoam? MMO? Used to clean gummed up oil rings?
  19. theshark
    theshark Member
    164
    Martinsburg, WV
    No oil leaks and no blue smoke.... it's baffling..
  20. JC91006
    16,761
    8,562
    Nothing baffling about burning oil at 200k miles. If it still drives Ok, just keep adding oil. At 1qt every 650 miles, it's still considered normal for Toyota. Pretty crazy eh?
    SM-N900P ?
    PriusGuy32 likes this.
