Flying and aviation stuff
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Mar 14, 2014.
  1. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Yes, I heard of the missing aircraft story. The 777 could be located, assuming the flotsam is indeed the A/C, thru the use of ROV submersibles. This would be tedious, long, hard work. The voice and flight data boxes would be the golden nuggets for extracting what went wrong. At the same time the crash site would have to be treated with the upmost respect for the deceased and the families of the deceased.
    DBCassidy
  2. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I thought this was funny and had to share it with you guys :D
    bwilson4web likes this.
  3. tochatihu
    tochatihu Senior Member
    9,516
    3,675
    Kunming Yunnan China
    2001 Prius
    When the search was near shore and on 200 m deep water I was optimistic. Both factors are less favorable in the current search area. Anyone know why the Orions and Posiedons cannot be refueled inflight? They are not getting much time on station.
  4. tochatihu
    9,516
    3,675
    2001 Prius
  5. bwilson4web
    15,991
    Satellite systems are certainly getting an unexpected workout. But so far, no confirmed debris has been recovered. If the aircraft broke up on the surface, there should be a lot of smaller floating debris (i.e., seat cushions).
    Speculation on my part, the Navy went with drogue and probe refueling systems and I suspect these don't scale well for the larger, multi-engined aircraft. The problem being significantly larger inertial masses and aerodynamic effects well beyond their bodies. The Air Force flying boom solves the problem by letting the boom operator fly the probe to the big and heavy.
    Now move an aircraft carrier into the area and the search problem is solved. But aircraft carriers are national resources.
  6. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    I spent some of Friday in meetings at the Chinese Embassy in Canberra - not about the plane, about other stuff. But some of my meetings were curtailed because everyone - even the commercial team - were tied up dealing with the search.
    The amount of work going on there to coordinate the search is extraordinary. A lot of it is just admin stuff - getting permissions signed off so that Chinese Air Force planes can base themselves out of Perth, and things like that. But all of the information-sharing that's going on between all of these countries (even countries that hate each other, like China and Japan, or countries that have fallen out quite badly recently like Australia and Indonesia) is actually a nice thing to see. It's a shame that it takes a disaster (and everyone being annoyed at Malaysia) to get everyone to work together, but it would be nice if we could all learn something from it.
  7. bwilson4web
    15,991
    1. ACARS should always be on and not be disabled by the flight crew.
    2. ACARS should have a battery pack providing enough power for a maximum duration flight.
    3. ACARS should include GPS data from an integral GPS source.
  8. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Well, yes. But what I meant was that it would be nice if we could learn something from the fact that, when necessary, countries that don't get on very well can actually cooperate and work together.
  9. bwilson4web
    15,991
    If only . . .
  10. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Not much '...difference..." between PIPE-DREAM smoke and WAR-COMBAT smoke.
  11. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Indeed. It was really nice to see what was happening at the Embassy, though.
  12. ETC(SS)
    6,924
    They did experiments with adding IFR to the Orion when they were doing ASuW work-ups with the Harpoons. Since the P3-Charlies already have 13 hours of endurance, crew fatigue rather than fuel becomes the limiting factor.
    Cruising around at 30,000 feet for 13 hours is one thing. Getting jostled about at search altitude is quite another!!!
    I'm thinking that if the pointy-heads at NavAir would have proposed an in-flight refueling mod for the Orions, then they would have met with more than a little resistance from the folks out on the sharp end.
    The P8 Poseidon is already IFR capable, and they have crew rest bunks, however (comma!) I don't think the juice would be worth the squeeze by committing tankers to this mission.
    Remember....UNLIKE most other parts of the federal government?
    The military has to operate on a for-real budget, and they're probably already 8 figures into what could be a non-domesticated goose grope.
    If a military unit runs out of cabbage, then ships stay welded to the pier, and planes stay in the hangar until somebody opens their wallets, or FY-next happens.
    If this were SAR? It would be a different matter, but this isn't that.
    YMMV.... :)
    tochatihu and bwilson4web like this.
  13. 70AARCUDA
    845
    209
    Tucson, AZ
    Pre-dating the USN's P3 Orions and current P8 Poseidons were the receiprocating "round-engine" Lockheed EC-121 "Warning Star" planes which had fuel capacity to stay aloft for close to 20 hours (8,760 gallons of 115/145 AVGAS at 100 gallons per engine (4 each) per hour), although the longest flights that I had usually lasted only about 16 hours. And, many of those hours were below 500 feet chasing typhoons in the pacific. Barrier flights were higher, between 5K and 10K.
  14. tochatihu
    9,516
    3,675
    2001 Prius
    I liked this piece
    Opinion: How mechanical problem could have downed Flight 370 - CNN.com
    favoring 'problems' over 'bad pilots' as an explanation. Please have a look.
    No one credibly offers hope for the souls on board. May they rest in peace. A quick cabin depress, quick unconsciousness would have been mercy. From any cause.
    We need a piece of the airframe suitable for forensics to find the cause. Considering the current search area, we might not get it.
  15. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    Fact be known, we are not privileged to all the facts up to this point. Only that which has been released to the press. It is my hope and belief that rapid progress be made in the following days, weeks and months that (1) gives grieving friends and families closure so they can begin healing process, and (2) so that changes deemed necessary can be enacted in effort to prevent another such catastrophic loss of life.
  16. Former Member 68813
    3,524
    983
    US
    I looked and the speculation is full of holes and wishful thinking.
    Let me just add some more facts about the captain.
    -2. The wife learned about the affair and moved out one day before the tragic flight. The captain called the girlfriend before the flight and things were not well either.
    -1. The captain attended a court session the day of the flight. His opposition party idol was sentenced to 5 years of prison for sodomy charge that was fabricated by the government.
  17. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
  18. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Where does it mention a Prius? Anyway, CNN is the "news" network that suggested a black hole might be the culprit. I kid you not.
  19. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    Must have been flammable aliens who came out of the black hole and hijacked the plane. They could be jealous of the Prius since it gets 60 mpg and is so damn quiet.
  20. Pasaman
    Pasaman Active Member
    289
    111
    Southern California
    I don't see a picture of a prius or a prius mentioned anywhere. Maybe it is because I'm reading in my phone?
