2013 Prius power mode
Discussion in 'Gen 3 Prius Main Forum' started by xerox6135, Mar 25, 2014.
  1. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    its because the throttle curve is applying more power earlier as you push the pedal. Ie dumping more fuel and opening the throttle plates faster. so it feels snappier and more responsive if you don't go to WOT.
    Once you get to WOT its the same power in all three modes.
    come down to VA and we can do some empirical testing between your 2010 iv and mine...I guess I'll have to get the paid version of torque since it will do 0-60 times...and run a test....
  2. Den49
    Den49 Member
    498
    272
    Maryland
    I agree. Power mode provides more fuel sooner which results in faster initial acceleration in situations when you need it most. Seat of the pants testing is all you need to measure that.
  3. MarcSmith
    471
    150
    Northern VA
    but if you push the pedal faster in ECO mode... you get the same result...as you would in power mode...
  4. Den49
    Den49 Member
    498
    272
    Maryland
    I doubt if my foot can push the accelerator as fast in ECO mode as the PCM can in power mode. If that were the case, there would not be a need for a power mode.
    HaroldW likes this.
  5. MarcSmith
    471
    150
    Northern VA
    we can try...:)
  6. Mendel Leisk
    41,384
    Maybe he just messed up his signature? He's complaining it won't stay in PWR. No matter, think h'e gone anyway, and the debate rages on, lol.
    I can't abide ECO, pedal travel way too long, think I'd have leg joint problem from all the excess tromping. Normal feels ok.
    WE0H likes this.
  7. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I often drive the wife's 2008 Prius. Its one and only setting seems to be more responsive than my 2010 in "default/normal" mode. So I drive the 2010 in Power mode all the time.
    WE0H likes this.
  8. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    xpcman When you live in a place like SF power mode is almost necessary! Steep in places. H
  9. xerox6135
    xerox6135 Member
    170
    94
    michigan
    The reason I said I would by no more toyota is this instead of toyota fixing the real problem they cop out with a software down grade on the car the recall they did on mine took a lot of power away from the car. I had the car for less than 30 days I get the software to keep the inverter from overloading the bipolar transistors and the end realty is I have full size Toyota Prius that my Prius c will run circle around so if that don't bother you that is great but I paid good money for this car and now it a slug
    WE0H likes this.
  10. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Oh beening everybody wants to call me a troll. I have a 2012 Prius c and a 2013 Prius persona nice friendly group here. And ya no shit a Prius c does not have a power button.
    WE0H likes this.
  11. bisco
    51,883
    well, it was confusing to see your c listed. you should join in the conversation in the thread about post recall power loss.
  12. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    I have driven the Prius C and even after the update, the Prius will still run circles around the C while still getting better mpgs.
  13. xerox6135
    xerox6135 Member
    170
    94
    michigan
    My bad I should have join that thread. Is there a way to show I own two cars. I didn't think about it showing I had a Prius c.
  14. bisco
    51,883
    i think you have to put it in your signature, or just mention it in the title when starting a thread.(y)
  15. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I am telling you my Prius c will run circles around my Prius persona maybe the software update didn't go right I will take it back to the dealer tomorrow and take service manager for a ride . I am afraid to pull out in traffic thats how slow mine is
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Many add both to their signature.
  17. bisco
    51,883
    that's crazy. i haven't read that whole thread, but i think some people are upset.
  18. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    I was reading a pamphlet at the dealership that said the power mode increases torque and decreases the time it takes to go from 50 to 70 by approximately 1.7 sec.
    WE0H likes this.
  19. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Yep, it provides more power, earlier:
    WE0H likes this.
  20. bisco
    51,883
    well it does supress hvac. still, i would love to see that brochure.
