Are My 17" Wheels Killing My MPG's...?
Discussion in 'Gen 3 Prius Fuel Economy' started by Skuits, Mar 26, 2014.
  1. Skuits
    Skuits Junior Member
    69
    Hi all, recently purchased a 2011 Prius 4 and it came w/ some 17" wheels - they look nice, but I am afraid they might be killing my mpg's? The tires are the same size that come on the Prius V 215/45/17. I am getting about 43 on the car's readout and a bit less by my calculations. I noticed that at 70 MPH the speedometer is off by 2 MPH slow, I am thinking this may be the reason the car's readout for MPG's is under my calculations...?
    I was wondering if anyone could confirm or deny this.
    I wish I knew someone who had a set of original wheels lying around I could try for a tank or so ;)
    Any and all input welcomed.
    Thanks,
    Mark
    dram91801 likes this.
  2. xliderider
    xliderider Senior Member
    8,054
    3,221
    Honolulu, HI
    It is physics. Wider, heavier tires, means more mass toward the outside of the wheel = harder to accelerate and get moving.
    Going down to 15 inch oem wheels with LRR tires will get you a few mpgs for sure. ;)
    SCH-I535
  3. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    It is my understanding that the speedometer and odometer are not connected like in older cars. while the speed will read a little under actuall, the odometer will be accurate with stock tires. everything seems to be complicated in how it works. I suggest you use a gps to see miles and compair that to odometer, or on the interstates there are some areas where they have odometer checks with mile posts.
    as far as do larger wheels hurt your mpg. yes they do. larger diameter wheels put weight further from the center of the wheel and it takes more energy to get them going. also larger tires will hurt mpg also with more resistance to rolling. How much does it make? I don't know. I have heard at least a couple mpg for 17 vs 15 wheel. also if the wheels are heavy it will take more power to get them spinning.
  4. BrianPB
    BrianPB Member
    114
    36
    Sylmar, CA
    My experience with my 17's seems to be the same. I get about 40 mpg in hilly suburban driving, over 5o mpg on the freeway at 70, about 45 mpg average per tank. I calculate about 2-3 mpg less than the computer readout. And the Speedometer is off by 2 mph at 70 as well. For some reason my car had 225 45 r17's (bought it used) I have considered picking up some stock 15" on craigslist to get a few more mpg's and tires are cheaper as well, but I really like the look of the 17's What kind of tires do you have on the car?
    Skuits likes this.
  5. Grren4ever
    Grren4ever Active Member
    347
    167
    Possibly heavy 17's and tires that are not low rolling resistance.
    What kind of wheels do you have? Post a pict for all of us to see and maybe we can find out the weight of the rim.
  6. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)With fuel mileage, more is alway best. For me, a loss of 2-3 mpg is insignificant on any vehicle that gets excellent fuel mileage. I have the Prius 5, 17" wheels and tires on my PIP. Nice wheels have always been important to me. A slight loss of fuel mileage is a trade off. The Telsa has a 21" wheel option and the Cadillac ELR comes standard with 20" wheels. They look fantastic.
  7. Skuits
    69
    Hi all, thank you for your replies. I've included a picture of the wheels they are 17 x 7.5. I looked at the manufacturers website and they don't have the weight of the wheels posted - going to email them. The tires are some cheapy brand - they don't appear to have a very deep tread. I've got them inflated to their max of 44 psi.
    I'd be happy to get what BrianPB is getting... Brian what are the measurements of your wheels? 17 x 7.5...?
    They appear to be from a Prius 5, are they?
    I purchased the car w/ the wheels and they do look nice, however I am replacing a 2001 Honda Insight CVT and was getting close 50 MPG and was hoping to do near the same MPG w/ the Prius just w/ more creature comforts. I'm only getting 42 per the car's report and am a bit disappointed. My neighbor has a Gen 3 Prius w/ stock wheels and states he's getting 47. My situation is that I drive a large grade to get to work. When I took the car in for service the Toyota Tech said yep 40ish is about right when driving the "grade". I was trying to rationalize b/c the Prius 5 has an option to come w/ 17" wheels and that maybe my "cool guy" wheels weren't cutting into my mileage and that maybe it was my driving style. I took the car on a 500 mile trip and was only able to get 43 in econ mode. I was driving at 74 MPH most of the time. I try to pulse and glide but I am not the best at it...
    I too would like to get some 15's and try it out w/ my "grade" drive. Hey Brian maybe we can go in on a set and share them ;)
    Anyone know of a mod to correct the speedometer? If the 5 has 17 there must be a way to adjust the speedo...?
  8. xliderider
    8,054
    3,221
    Honolulu, HI
    It sounds like you might not have LRR tires on there? That can make a significant difference in fuel economy, especially in a 17" tire size.
    Even if the speedometer is dead on, the mpg displayed by the Prius is only an estimate, and it is almost always optimistic, often by as much as 5% or so.
  9. Skuits
    69
    Hey Don what sort of mileage do you get w/ your 17"?
  10. Skuits
    69
    That's good to know - I know that I'm about 2.5 mph slow, so I just comensate. It only seems to be that different at the higher speeds - slower speeds seem to have less of a difference.
    What are some LRR tires in that size? Seems like I saw a list at one time...
  11. iOSTodd
    iOSTodd New Member
    I have the same problem, 17" rims with cooper zeon rs3-s tires and i'm only getting 36 mpg so far. I've only had the car for two weeks and not really driving too hard on it, was wondering if something was wrong with the car.
  12. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    There are just so many factors it's hard to tell.
    1. Driving style
    2. How fast you go
    3. Do you coast or stay on the gas?
    4. Outside temp
    5. Short trips are really bad for mileage since it's not warmed up
    Could go on. Wheels *are* just one factor of many.
    My wife averages about 46mpg in our Gen II so it is possible to improve!
    Could also check your engine air filter.
  13. iOSTodd
    iOSTodd New Member
    During the week my trips are about 6 miles each way to and from work. I'm in Colorado Springs so I have some hills in my area. Of course with the time of year it is quite cold in the early morning when I leave for the day. As far as my driving style I usually accelerate as hard as I need to to get up to speed, or gradual if there's light traffic with nobody behind me then i'm usually in the lower to mid portion of the eco bar to maintain speed. But if that's the reason why is because of shorter trips then I could live with the lower mileage cause in the end it's qualitative, i'd just like peace of mind that nothing is wrong with my car.
  14. ewxlt66
    535
    186
    Dana Point, CA
    6 mile trip in cold is the issue.
  15. Skuits
    69
    What size wheels/tires are on your Gen II?
  16. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    How does that work? It doesn't make sense to have 2 different distance measurement devices. I would be very surprised if changes to tire sizes diameter are automatically compensated for by either the speedometer or odometer.
  17. vskid3
    vskid3 Active Member
    773
    228
    The actual tire diameter should be sil
    The difference is the same percentage wise, which makes it easier to see at higher speeds. 10% of 10 is 1, 10% of 100 is 10, which looks more off on a speedometer.
    Did your Prius come with 15" or 17" wheels? Going off the sizes listed for the 2014 models (which I assume are the same), the tire on the 15" is slightly taller, 807 revs/mile for the 15", 819 revs/mile for the 17", so if your's came with 15" wheels, that's probably your problem. (note, wheel size is independent of tire size, to a certain point, so its not weird for the smaller wheel to have a taller tire)
    I averaged 48MPG over 1800 miles on a recent trip in my '05 doing 68-78mph on cruise (whatever the speed limit was plus a few). 15" wheels, LRR tires pumped to the sidewall max of 51PSI, and a lower grille block. Sure, it rides like a truck, but I love my MPGs.
  18. vskid3
    773
    228
    Its done in the computer. The computer uses the correct speed for the odometer and running the car, the speedometer just displays a slightly higher speed. I think all the car's I've used an OBD-II scanner on displayed the correct speed through OBD, even though the speedo was high. I don't know of any cars that compensate for the tire size, though. There may be a setting the dealer can change that will correct it.
  19. xraydoug
    571
    176
    Roseburg, Oregon
    I am going by what I have been told. many have made the same comment on other threads. in general they say that the odometer will be accurate because the warrenty goes off this. they read a little fast on the speedometer so their cars don't under state mph. I think that Honda lost a class action lawsuit due to their odometers running fast. so people would believe they were getting better mpg, and they would have car problems that would not be coverd by warrenty due to inaccurate odometer.
    Stratman likes this.
  20. iOSTodd
    iOSTodd New Member
    I bought it used with the 17" rims on there
