Declining MPG; HSI Bar goes to "PWR" more often
Discussion in 'Gen 3 Prius Fuel Economy' started by jamesmaya, Mar 28, 2014.
  1. jamesmaya
    jamesmaya Junior Member
    28
    I
    Hello. I purchased a used 2010 in December 2013 with about 28k miles.
    I started out with 53-54 mpg but I've noticed a measurable decline in fuel efficiency over the past couple months. I refuel about once a week and track the mpg. I was at 50.4 mpg on 2/1/14 and down to 48.2 mpg on 3/21/14 with gradually declining numbers in between these two readings. Variations in driving conditions don't account for this as I use my vehicle almost exclusively for home-to-work commute (about 60 miles daily, Southern California). I'm in Hybrid mode all of the time. Tire pressure seems ok, too. I've also noticed recently that it requires less pressure on the gas pedal to get the Hybrid System Indicator bar into the "PWR" area; previously the bar was mostly in the "ECO" area.
    Any thoughts on what might be going on?
    Thank you.
  2. neez
    neez Member
    194
    37
    Check your tire pressure, air filter and 12v battery to start.
    jamesmaya likes this.
  3. bisco
    52,194
    i agree with the 12 volt. did you have the recall done?
  4. jamesmaya
    28
    I
    Thank you, will do.
  5. jamesmaya
    28
    I
    I have not had the recall done yet, but will schedule that soon with the dealer. Is there a connection between the recall fix and my mpg issue? Thank you.
  6. bisco
    52,194
    no, but some have noticed less power after the recall, that's why i asked.
  7. jamesmaya
    28
    I
    Gotcha, thanks.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Do you always fuel up with the same brand of gas?
    I have noticed fluctuations, in Fuelly, where my mpg had gone down significantly for several tankfulls, only to go back up.
    I wondered if I just got a bad batch of gas, or the local refinery wasn't putting out what they should have quality wise during those times. :confused:
    SCH-I535
  9. jamesmaya
    28
    I
    Yes, always the same brand, same gas station. Thank you.
  10. macman408
    1,179
    367
    The car is more likely to go into PWR when the hybrid battery SoC is low. How many bars do you see when this happens? If you're driving in EV mode a lot (intentionally, or just by pressing lightly on the gas pedal so the ICE is off), that can drain the battery quickly. Then it has to run the ICE harder next time it's on to fill the battery back up again. So it's possible that a change in your driving style is causing it...
  11. jamesmaya
    28
    I
    I believe the car is more prone to go into PWR when there are fewer than half of the battery bars showing, but I'm not certain so I'll have to pay closer attention to this. I use EV only in parking lots. But I think you may be onto something about having a light touch on the gas pedal and driving style -- I've always thought that the idea was to keep the ICE off as much as possible. Thank you.
  12. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    You have the right idea, but you also need to add to the mix about trying to keep the SOC at least above the middle of the readout (60%) As everyone has stated, the bar will move over towards the power end easier when the SOC is low.
    You mentioned EV use in parking lots. You will actually come out better if you limit your EV usage to strictly moving the car around in the driveway at home. If you leave it in normal mode or ECO, the car will automatically use EV mode if the SOC is 60% or more and the force on the go pedal is slight along with the speed being lower than the cutoff of 40 something. Watch the indicators on the dash when you are driving in normal mode in a parking lot and you will see what I mean.
    The beauty of the Gen III over the Gen II is the redesigned HSI bar that are you talking about. It actually allows the user a easier method of controlling energy flow and usage thus getting the optimum MPG.
    Use the ICE as needed to recharge the traction battery. Also use regen as much as possible for maximum regen back to the traction battery.
    Best of luck to you!
  13. bisco
    52,194
    what do you mean by " i'm in hybrid mode all the time "? there are 3 available modes: eco, normal and power. if you changed from eco to normal or power, or normal to power, the accelerator becomes more sensitive with the same amount of foot pressure and the his bar will move more quickly to the right. this will accelerate the car faster and possibly use more fuel if you don't comprehend what's happening.
  14. jamesmaya
    28
    I
    Sorry, I meant to say "ECO" mode (not "hybrid").
  15. jamesmaya
    28
    I
    Thanks!
  16. dorunron
    3,318
    1,105
    Houston, TX
    From what I have learned so far, on the Gen III you will do better running in "normal" mode for around town and ECO mode when you are on the highway. "Normal" mode is when Power, ECO and EV is not lit up on the selector buttons.
    Gen III Prius actually has four different selections to choose from. The selection you choose will modify how the go pedal works and also adjust the A/C some.
    Remember this no free ride with the Prius. The power in the traction battery mainly comes from the ICE. Some of it comes from regen. You will actually do better if you hypermile using pulse and glide methods than you would straight driving or trying to drive in EV mode all of the time.
    Read the link in my signature about how to hypermile. It is for Gen II, but the principle still works in Gen III. When gliding in a Gen III, the HSI indicator will show nothing or a small amount. Look closely at the pic I posted above. Note the area that is marked "Optimal Gliding Here". Learn about P&G and use when you can. You should see a increase in your overall MPG.
    Here's a great video on hypermiling a Gen III Prius you can watch.
  17. jamesmaya
    28
    I
    Excellent. Thank you!
  18. Former Member 68813
    3,524
    983
    US
    When I drive in city/suburban, I use the gas pedal as an on/off switch and keep the HSI at either yellow of green zone (as close to extremes as possible). The benefit is the best MPG and the least wear and tear on the HV battery.
    I figured out very early on that forcing EV as much as possible resulted in bad MPG numbers and lots of battery cycling. Now, I do the opposite, force ICE as soon as I get in the car.
  19. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    for the last few tanks I have been exclusively using ECO mode. and my MPG indicated has been around the 45 mark. (42-43 actual)
    this current tank I am running in normal mode and halfway through i am holding at 49. but we have had warmer weather as well. and I am driving the car keeping an eye on the HSI gauge and staying out the PWR range and not doing anything else special. kinda keeping up with traffic ect.
    After running inco mode for a few thousand miles, its hard to get used to the pedal sensitivity in normal mode.
  20. dorunron
    3,318
    1,105
    Houston, TX
    I do agree that ECO seems to have the "response" that I am familiar with in comparison to the Gen II on the new Gen III.
    At first I didn't see or feel the difference, but upon further driving in both normal and eco mode, I found that I prefer the eco mode also. Even if I don't hypermile using P&G I am seeing over 50 on the computer. Will know more after a few tanks of fuel. I believe if I go with the old standard of P&G which basically means using ice in mid to upper range without hitting close to power zone and then feather back to bottom of the HSI as the two of you are talking about and also as the video shows, that the MPG will be much better.
    I do agree that the sensitivity is much greater in ECO mode than normal mode thus giving you better control over the go pedal.
