Where does this plug go into?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kitkit201, Mar 29, 2014.
  1. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    I found t dangling when I was vacuuming. Where does it connect to?
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    I do not know, does not look factory to me, did you buy the car used?
    If so maybe it is a add on of some kind from previous owner.
    Some one with better insight will chime in, just hang in there.
    kitkit201 likes this.
  3. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    It has a L bracket so that makes me think it is factory. Yes I bought it used.
  4. Tande
    Tande Active Member
    537
    321
    Mich.
    I would agree.....does not look OEM.......
  5. RRxing
    RRxing Senior Member
    2,545
    1,820
    NEPA
    Where was it dangling from? Location would help, although I agree - doesn't look OEM.
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I know they've gotten cheap with the interior materials, but they haven't started splicing wires together with electrical tape as your original pic shows. It looks cobbled together. The previous owner had something wired into it but I have no idea what it was.
  7. pmike
    pmike Member
    237
    81
    Central Florida
    Probably a cable for the sub prime vehicle financing disablement device, when you don't pay, you don't drive.
    ou812 likes this.
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Take a multimeter to the two pins to read the voltage with the car on and off. If it reads some constant voltage, it is probably an added power supply tap for something the previous owner had. Nearly every sensor on the car has some type of check, so if your engine check light is off and everything else is OK, then the probability it is an unplugged sensor is rather low. Meanwhile the number of gadgets some drivers want to add to the dash is insane....and every one of them needs power.
  9. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    Thanks everyone. I'll write this off as a no worries
  10. PriusInParadise
    180
    91
    Hawaii
    Its for the Tire Pressure Monitor Reset Switch.
    The switch is mounted to the left lower IP closeout panel, just to the right of the Diagnostic Link Connector. I've circled it in Red
    Are you missing the closeout panel?
