Sokie Tech Hood Strut - DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Plus IV, Mar 29, 2014.
  1. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I ordered the white colored hood struts off ebay. Received them in a week.
    2009 2010 2011 2012 Toyota Prius XW30 White Color Shock Lift Hood Damper D4N5 | eBay
    They came well packaged and the instructions were very easy to follow.
    Install the new bracket and reinstall hood bolt. You have to remove the small silver pin from the strut socket. This pin, when reinstalled, will keep the strut from coming off the bracket. IMG_0082.jpg
    Repeat the small pin removal, attach the socket to the new bracket and reinstall the pin. Here is one side complete. IMG_0085.jpg
    Repeat the same process on the other side. The first side took a little longer due to making sure I followed the directions. The other side took 5 mins. to complete. In all, it took around 15 mins. to install. IMG_0086.JPG
    One thing they don't say in the instructions is to remove the old stick support. I did because the bracket rubbed the strut body just enough to nick the paint. I repaired it with touch up paint. Maybe you can bend the bracket to clear the strut body and leave it in to retain the stock look. IMG_0087.jpg
    The struts work great and the white is a close match to the BP color. I would highly recommend these if you hate the hood support stick.
  2. toyopri808
    toyopri808 Active Member
    226
    116
    great writeup! thanks!
    Plus IV likes this.
  3. Seanzky
    Seanzky Member
    150
    28
    NY
    Thanks for this thread. I'm still waiting on my order. I, too, got the white one.
  4. neez
    neez Member
    194
    37
  5. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I wanted to put this thread together so anyone who was interested in these could see how easy it actually is. You will definitely like the white. They don't look like stock black struts. And I didn't do the carbon fiber because I don't have anything else that has CF.
    PlusIV
  6. Seanzky
    Seanzky Member
    150
    28
    NY
    I share those very exact same sentiments. Not to mention, choosing black would cost a few more dollars... for what? It's not like it's at the center of the engine bay where 99% of the stuff are black. It's at the edge where the body of my car is white. Also, I'm not a big fan of fake carbon fiber or carbon fiber looks-only.
    Plus IV likes this.
  7. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Did you have to cut the plastic next to the fuse box? I think if you close it. The top will rub against the damper on the right? I think L or R the same. I notice that on your picture you have the L install on the R side. Not sure if it matter
  8. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I could be wrong, but looking at the instructions photo, it looks correct to me. Besides, when you make a left turn, you are inside the vehicle, not standing in front of it. AFAIK, directions on a car are always relative to the driver position.
  9. Seanzky
    Seanzky Member
    150
    28
    NY
    Whatever you do, just follow this thread. Don't follow the instructions. It confused the hell out of me.
  10. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Will these fit a 2014 Four?
  11. apt5020
    881
    1,294
    Prius City, CA
    Did you use the washer that came with it? My hood damper came with 8 washers. I see that you use the original factory bolt near the headlight. I had to buy new one since it wasn't long enough.
  12. okdonk
    okdonk Junior Member
    29
    Las Vegas
    Thinking to get this done to my brand new Prius. Thank you for the guide pics.
    Th
  13. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Thanks Plus IV, just got mine from Xterra72. This will be very useful.
    Xterra72 likes this.
  14. Xterra72
    Xterra72 Senior Member
    1,435
    1,681
    I used this same thread to install my hood struts.
  15. Mr_Raja
    Mr_Raja Junior Member
    22
    Germantown
    Just got a set installed in my 2015 Prius over the weekend. I was able to find the black ones, since my Prius is Sea Grass Green. Seems like Sokie changed the design a bit. The one that OP posted the pictures of seem to have metal connectors with a safety pin that has to be installed separately. The ones that I got has plastic/nylon connectors with the safety strip already installed in side the connector. I did buy them from the same seller, seems like he is the only one authorized seller on Ebay out of Taiwan.
  16. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Looking great! One question though. Can you open the fuse box cover after the install? It just looks very close to it.
  17. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    yes, the fuze box is still accessible :)
