Did Toyota Move the Location of the VPNS in 2014?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Keith Hollister, Mar 30, 2014.
  1. Keith Hollister
    Keith Hollister New Member
    Read the threads about the VPNS and figured I would disconnect mine.
    It's not there. I pulled the liner from the driver side front wheel well liner, nothing. Looked down from the engine compartment with a flashlight, see the headlights, running lights and nothing else. No speaker, no wiring harness going anywhere except the lights and a grounding terminal on the frame.
    Anybody had a confirmed sighting of this thing on a 2014? Or am I just blind as a bat?
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,458
    92
    Could it be this thing in the foreground?
    The part number printed on the label (on the blue side) is: Denso 068900-5390. A little googling around suggests this is some kind of a buzzer.
    I was considering pulling the plug on it when I was doing my horn upgrade.
    HaroldW likes this.
  3. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    yep, that's it/
    just unplugged & removed it today/
    wasn't working neway....////
    Dylan Doxey likes this.
  4. Keith Hollister
    Bingo! - thanks Dylan. Now to figure out how to get to it without pulling the bumper.
  5. Dylan Doxey
    1,389
    3,458
    92
    Take a look at the horn upgrade thread. It shows how you can remove the nose emblem and get easy access that way.
    Horn Upgrade
  6. Keith Hollister
    Ah - thanks. I'll give that a try when I get the car back - I dropped it off at the local Classic Soft Trim install center today to have leather installed.
