Gas Tank Slosh Noises, normal?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by aomC, Apr 7, 2014.
  1. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    Has anyone noticed that when the gas tank is full, it makes an audible sloshing noise when coming to a stop or going into a parking lot ramp. For a few days, I thought that something was loose in the rear suspension or trunk, then realized it was the fluid in the gas tank. Of course, I generally notice it only when the radio is off or low and I'm performing the above tasks and the ICE isn't running.
    Can others confirm if they notice it too? Just want to be sure it's "normal".
    Finally, does the PiP still use that Gas tank bladder like in the 2nd gen prius?
  2. Okinawa
    Okinawa Senior Member
    1,333
    320
    I have a 2011 Prius that I bought new. You have certainly given me something to think about. Occasionally I hear something in the back that sounds like a rattling sound. I could never find the rattle. Maybe it what you are hearing with the gasoline.
  3. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    Yeah, I've got to believe it's normal (I remember my 08 Touring having a slight noise, but it seems louder on my 14), but I'd like to know if others have noticed it as loudly.
    When I realized it was the gas, it was only after the car came to a stop you hear a slight noise in the back, then a second or two LATER (after the car has already stopped), you hear an additional slosh/bang (well, more like a light thump) noise in the back (like water hitting the side of a bowl, since that's probably what's happening).
  4. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    No fuel tank bladder in any 3rd gen Prius.
  5. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    Whew, that's a relief. I don't live in a cold climate, so the bladder issue in the 2nd Gen didn't affect me, but it's one less thing to worry about.
    But then I'm thinking w/o that inflatable bladder, that might be why I hear the sloshing sound more? Plus when the tank was half full, I heard it less too, maybe as it gets to the top, the liquid is closer to the seating area, so you hear more of the movements.
  6. Okinawa
    1,333
    320
    I have the same Prius as Munpot42 so the noise in the rear of mine no doubt is something that rattles once in awhile.
  7. bisco
    51,841
    i have never heard anything. look in the battery area to make sure rain hasn't leaked in. of course, i'm half deaf, so maybe i just can't hear it. it does have it's advantages.:p
  8. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    yeah, no rain ;)
    I drove again today to run some errands, no radio, no ICE, no AC, stopped abruptly and heard a slight sloshing noise, seems to come right from the bottom of the rear seat (where the gas tank is). The tank is full too, but at about half, I don't think I notice it as much.
  9. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    It'd be great if someone could full tank it, then drive around and see if they notice the sloshing noise after abruptly stopping.
    I looked at some old posts on priuschat and it seems like others have noticed it before on then 2nd gen Prius (also when the tank is full), otherwise I suspect when it's close to half or empty, you're not going to notice it as much. I can just turn up the radio too... the car is just SOOO quiet, you tend to hear everything. Especially running in plug in power only (which I've spent the past 3 days doing, 80 miles, all plug in), I kind of forget what the engine sounds like!
  10. bisco
    51,841
    it's a beautiful thing, isn't it?(y)
  11. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    Truly
    Truly! Also, the time it's going to save by not having to get gas as often can't be measured.
  12. bisco
    51,841
    exactly, i haven't bought gas since february!;)
  13. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I noticed it in my 2012 PIP every single time I filled it up then backed into my (slightly uphill) driveway and stopped! Even joked about it with my wife...
    It's normal- nothing to worry about. As soon as you burn through a gal or two the sloshing stops.
    aomC- reconnect the noisemaker and you won't notice the sloshing anymore :p
    aomC likes this.
  14. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    I noticed it after filling up last time.
  15. bisco
    51,841
    looks like you're good to go, whew!(y)
  16. retired4999
    2,652
    627
    Eau Claire, Wi.
    I never gave it a thought, yes! mine does slosh. Welcome to the club!:)
  17. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    Thanks for confirming everyone!
  18. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Seems like you'd hear more noise with a half full tank than a full one
    Mike
  19. bisco
    51,841
    i was thinking the same think. defies logic.
  20. El Dobro
    El Dobro A Member
    7,087
    3,265
    After driving Jettas around where the fuel tank sounded like the shore during a storm, I don't hear a thing.
