How to wire amp with dash speakers?
Discussion in 'Gen 3 Prius Audio and Electronics' started by psteudlein, Apr 8, 2014.
  1. psteudlein
    psteudlein New Member
    27
    I have a stock HU, non-jbl, 6 speaker system. I have already changed out all 6 speakers, with a 300 hz high pass filter on the dash speakers.
    I plan on getting a 5 channel amp, nothing crazy, just want the music louder with some bass.
    But I am not sure how to hook up/wire up the dash speakers with the amp. 2 channels for front door speakers, 2 channels for rear doors, and 1 for sub...but what about the dash speakers.
    For others who have added an amp, how did you wire the 6 speakers?
    Do I just not amp the dash speakers, and let the stock HU continue to power them like currently?
    Did some of you just not use the dash speakers?
    If I wire the dash speakers with front door speakers on the 2 channels for front, won't it cut the total power to the front door speakers?
    Thanks for any help or suggestions.
  2. Chris S
    Chris S Active Member
    323
    109
    Gilbert, AZ
    Some of us left the front squawkers alone. Even with amplified door speakers, you should still hear them.
    I tapped into the speaker harness at the door-body connectors so I didn't have to pull the HU or fish new wire into the doors, was a little lazy but it worked. I cut the wires and ran the radio output to the LOC and then the speaker side from the amp. This link has a little info on the wiring at the HU but if you just search the forum for wiring diagrams, info is there.
    Radio wiring diagram | PriusChat
    Good luck and keep us posted on your progress!
    iPhone ?
  3. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    How you wire it up will depend on what your setup is. I assume you are going with a set of components with a crossover for the front? If so you are going with a passive setup. From the amp, you would run the front two channels to each of the crossovers (one per side) and then one output would go from the cross over to the woofer in the door and the other to the tweeter in the dash. If you are going active in the front, that is a whole different setup.
    Does the amp accept speaker line outputs? If not, you will need a line output converter.
  4. frodoz737
    frodoz737 Top Wrench
    4,693
    2,493
    33
    It will sound much better to have component speakers up front with real cross-overs, with coax in the back. With one each channel to the two cross-overs and one each channel to the two rears, then save the fifth channel for a sub later. Base blockers are just cost cutters for factory installations and sound like it.
    Chris S likes this.
  5. BillyBuerger
    BillyBuerger Junior Member
    26
    I
    What speakers did you get for the replacements?
    Car manufacturers love to list out how many speakers the system comes with. 6 speakers is better than 4 you know. :) But really what they are saying is that they actually used component speakers for the front instead of a cheap single speaker, maybe with a whizzer cone. If they used component speakers in the rear, they would have called it an 8 speaker system. BUT, it's still a 4-channel system, 2 front, 2 rear. They use a very simple crossover system where they cut off the low frequencies (bass blockers) to the tweeters and let the natural response of the woofers to cut the high frequencies there. It's not ideal but it works.
    I would recommend a similar setup. It's not helpful or at least is more difficult to tune with two sets of speakers coming at you from the front. If you want to use the door+dash, the doors should have a crossover themselves to cut the high frequencies and leave those for the dash speakers. Assuming you use the 300Hz high-pass cutoff for the dash, you would want a 300Hz low-pass for the doors and run both off the front channels of the amp. The door+dash is acting as one speaker at that point. But that's a bit of work. And it's easier if you get a good component speaker for the front to put the woofer in the door and tweeter in the dash. The crossover would already be tuned and you wouldn't have to try to do the same yourself. Again, this is what they are trying to do with the stock setup.
    Chris S and frodoz737 like this.
  6. frodoz737
    4,693
    2,493
    33
  7. psteudlein
    27
    Thanks for all the replies.
    Recap again: I have replaced all 6 speakers. The fronts, dash and door, are not a component set. Dash speakers are 3.5 polks, front doors are 6x9 infinity reference, and rear doors are 6.5 polks.
    Dash speakers have a 300 hz high pass filter in the line for them. Stock hu.
    Sounds ok, but I want it louder...running sound at 45-55 level.
    So I want to add a 5 channel amp.
    Can I convert the front sets, dash and door, to a component set with some type of crossover?
    Is everyone's rear door speakers useless without an amp?
    I do plan on using 2 line out converters to run to amp.
    But my main issue, is what to do with dash speakers with 5 channel amp...hence, back to my original question.
    Do I just not hook up the dash speakers to the amp?
  8. Chris S
    323
    109
    Gilbert, AZ
    I think you should install the amp for the door speakers, listen to the sound, and go from there. Your door speakers are good choices and once amplified, they will definitely sound good. The 3 1/2's will still provide some front fill off the windshield but speakers that small aren't designed to be your main source for sound, leave that to the larger ones. You want to know they're there but they don't have to blast as much IMO.
    If you don't like it in the end, then the choice is really up to you and what you want out of it. You could:
    1) leave them
    2) get a second small amp for them
    3) swap them out for components or as mentioned, get passive crossover sets and wire them as a set.
    There's a ton of possibilities.
    I think the back door speakers definitely need to be amplified if your doing the fronts. If given a choice, do the rear doors over the dash ones.
    Your speaker choices are good. What amp and LOC's are you using?
    iPhone ?
  9. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I have a 5 channel amp and I am going to go with an active system instead of a passive. My plan is to skip the rear speakers altogether or just run off the head unit. Purists will say it messes with your front sound stage too much.
    My planned setup:
    The head unit goes into a DSP where it does the LOC, processing (cross over points, time alignement, etc). The DSP then goes into my amplifier. 2 channels on the amp will be used to run the full-range dash speakers (crossed at 300-2000 hz depending on the speaker). The other 2 channels will run the woofers in the door. The 5th is reserved for a subwoofer. This method is more expensive and complicated and may not be for you.
    The alternative would be to go with the passive design. This would allow you to use 2 of the amp channels to power the 4 front speakers and then the other 2 channels to power the rear. You can acquire new crossovers to match your existing speakers. You may be able to pick some up used as they are often discarded in favor of a passive setup.
  10. psteudlein
    27
    I have not selected the amp yet, but was leaning towards:
    Alpine MRX-V70
    Polk PA-D5000.5
    I also plan to buy some type of LOC to help boost the signal from the HU...or maybe get some cheaper 4 line DSP that does cost a fortune. Any suggestions?
    My dash and front door speakers are not a component set.
    Is it possible to make them a set if I get an active crossover? Any suggestions?
    So I guess my choices are:
    1) Do not hook the dash speakers up to the amp, just run from the HU with the passive high pass filter on them.
    2) Get some type of Active crossover for the dash and front door speakers, and wire all the speakers up to the amp. Dash/fronts on 2 channels with crossover (as a component set), rear doors on 2 channels, and the sub on 1 channel.
    Questions for option 2.
    If dash and fronts are one 2 channels, and say amp does 50w, does that mean the 50w gets split between the 4 speakers (2 dash and 2 front doors)? If this is the case, it seems I would not be getting the most out of my front doors if they are good up to say 100w rms
    But if the dash speakers were left just to the HU, all 50w would go to front doors?
  11. Chris S
    323
    109
    Gilbert, AZ
    I'm not so sure on others' choices but I use and like my Audio Control LOC, LC6i. It's not packed with options but makes a nice signal to my amps. It takes 4 channels in and creates 4 plus a 5th sub out.
    I ended up having a little noise at the sub amp so then threw a cheap Power Acoustic active crossover between the LOC and amps and am noise-free and pretty happy with the sound.
    The Infinity's are nice speakers and I like that Alpine amp. I think you'll get some nice sound and it's so nice having 1 amp do it all, unless one of the channels gets an issue, then you lose the concept. I had an old Soundstream 5 channel amp I loved but then the sub channel went bad and smoked a woofer. :-(
    Holy crap it stunk!
    As for the dash speakers, I still think you could leave them. If you want an easy an flexible addition, maybe try the Alpine Power Pack; it fits under the dash and would take the dash speaker wiring as inputs. Plus you'd then have 2 extra channels to play with if you need.
    iPhone ?
  12. psteudlein
    27
    Where do you have all the various items located in the car: LOC, crossover, and amp.
    Did you replace the dash speakers? Are they just wire to the HU only?
  13. Chris S
    323
    109
    Gilbert, AZ
    I put the LOC and X-over under the passenger seat. I broke into the speaker harnesses at the kick panel and rear door connectors so I wouldn't have to pull the HU and also run less speaker cable to into the LOC. My original plan was to connect the LOC to the amps and be done, but I ended up with noise on the woofer, a low periodic rumble. I did a little testing around and found it came from the LOC, so I then added a cheap Power Acoustic crossover into the mix and it cleaned up the sub nicely and gave me a better selection of things to tweak all around. I moved the sub RCA from the LOC to the x-over. Both units take 4 channels in and create 5 out with the sub.
    I did nothing to the dash speakers, still stock. I waited until all else was done and realized they were fine for me.
    I attached a drawing of my system and variations to it based on another wiring diagram I found on the Forum. You'll see how the dash speakers may be wired. My drawing is a little out of date and colors specified may not be accurate. I just need to insert the x-over between the LOC and amps and move the sub output from the LOC to the x-over.
  14. BillyBuerger
    26
    I
    I'm using the Alpine MRX-V70 amp myself and have been very happy with it. It has built-in support for high-level input which I am using currently. I haven't noticed any issue with it that would push me to look into getting an external LOC. That's just my personal preference. It's good enough for now and we'll see what I decide to do with the HU in the future.
    As for Option 2, if you setup a passive crossover (speaker level inductors and capacitors), then you have the same 50W from the amp as you would with just a single set of speakers. It's just that you're splitting that 50W between two sets of speakers instead of just one. The lower frequencies will only go to the doors and the higher frequencies will only go to the dash.
    So I guess you would be "wasting" the tweeters in the door speakers since they won't be used at all. But that's by design. The dash speakers should give you a better sound stage for the high frequencies than the doors. So that's where you want them. And doubling up on the high frequencies could make the sound too harsh or require equalization which is going to reduce the amount of power to the tweeters anyways. Just requiring more work to do that.
    Chris S likes this.
  15. psteudlein
    27
    So you have just the amp and no LOC and all is fine.
    Did you replace all 6 speakers?
    Are your dash speakers wired up to the amp, or just off of the HU?
    Where did you put your amp in the car?
    Do you have a sub, where?
  16. psteudlein
    27
    Chris,
    Thanks for that wire diagram and other information you provided. I will probably just leave the dash speakers wired to the HU and see how that sounds.
    Did you do all the work yourself?
  17. Chris S
    323
    109
    Gilbert, AZ
    Yep, love to play in the cars. Each one is a new learning experience, especially this one since I had to make sure I can get the spare tire out. I only wish I had more time for better custom jobs.
    I'm looking forward to seeing and hearing about your setup once it's all done.
    iPhone ?
  18. JGI
    JGI Member
    77
    46
    Sure, I've done this many times. You'll need something like this:
    ebay link
    Yes, these are not "matched" with the mid and dash tweet you have, but trust me it will work just the same.
    My preference is that the front stage gets all the power and the rears are just for "fill", that's why they're called "rear fill". You can get away with not amping the rear speakers, but of course you get more control if you do. I'd say amp them.
    Buy that passive Xover I posted above (or something similar) and wire your speakers as normal.
    Front output from amp ----------->| Xover |-------------> Dash speakers & Door Speakers
    Rear output from amp -------------------------------------->Rear Door speakers
  19. psteudlein
    27
    JGI,
    So for a 5 channel amp, you suggest, 2 channels for dash/fronts(with a crossover you suggested), 2 channels for rears, and 1 channel for sub.
    Question:
    So if the amp say does 60w rms per channel, have the dash and fronts in series, does that mean 30 goes to the dash and 30 to the front? But if I just wire the fronts, all 60 go to the front? If true, then the fronts would not work to their max if they could handle 100w rms.
    Sorry for all the questions...I am far from a car audio expert.
  20. BillyBuerger
    26
    I
    Yes, the amp has a built in LOC so the speakers wires can plug right into there instead of using the RCA inputs. It's also able to use that for the remote turn on. So I don't have to run a wire for that. It turns on really fast with no thump. Only a small little chirp when turning off.
    Currently I have just a pair of Infinity Kappa 62.9i speakers in the front doors and a shallow mount Pioneer TS-SW3001S4 sub in the hidden compartment with the amp. Dash speakers are disconnected. I haven't posted many pictures yet as it's still pretty rough and incomplete. I've posted a very little thing on CarDomain about it. The goal would be to pick up a pair of Infinity Kappa 60.9cs components with the woofers in the front doors and tweeters in the dash. Then I could move the 62.9is to the rear doors.
    You would wire the front door and dash speakers in parallel, not series. With no crossover and just plugging both sets of speakers in, you would be running at a 2ohm load which could pull even more wattage from the amp. Possibly too much. (I'm simplifying here) The crossovers would act to split the signal so that it acts more like a normal 4ohm load instead of 2ohm
