backup camera screen return
Discussion in 'Gen 2 Prius Main Forum' started by elmofongo, Mar 8, 2006.
  1. elmofongo
    elmofongo Member
    256
    SF, CA
    I noticed that while I'm backing up, I change the screen by selecting audio or climate, I cannot get back to the camera view. Perhaps I didn't wait long enough?
    Anyone noticed this?
    -Adriano
  2. unruhly
    unruhly New Member
    205
    Do you have "Auto-Return" turned off? It's one of the screen setup settings. (Might only be with NAV though.)
    It causes your screen to return to the Map or Energy screen after 7 seconds? if you change the radio station or the climate controls.
    I'd check that first.
  3. McShemp
    McShemp New Member
    371
    SA, TX
    I haven't been able to get the camera back when that happens. I suppose you could get out of reverse and then back into it ... or just hold off changing anything until you finish backing up.
  4. elmofongo
    elmofongo Member
    256
    SF, CA
    yep, It looks like there's no way back unless I get out of reverse and back again.
    I have auto-return on but it didn't help.
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Nothing personal, but I think I'd rather have you paying attention to backing up than fiddling with the radio or climate controls! :) Can't be backing up for so long that you need a different radio station can you?
  6. McShemp
    McShemp New Member
    371
    SA, TX
    Yeah but you can start backing up and remember to activate EV mode. That takes you to the screen with the battery SoC on it.
  7. elmofongo
    elmofongo Member
    256
    SF, CA
    I actually commute to work in reverse.
    it's much more relaxing!
    :lol:
  8. kente777
    kente777 New Member
    194
    NW Florida
    Yeah, and you don't use any gas that way!
    Ken
  9. elmofongo
    elmofongo Member
    256
    SF, CA
    Not to mention all the miles I erase from my odometer!!
