Eibach lowering springs
Discussion in 'Prius v Accessories and Modifications' started by teckit604, Apr 12, 2014.
  1. teckit604
    teckit604 Junior Member
    2013 Prius v wagon
    Just installed Eibach lowering springs, it's about 1.5" drop front and rear.
    Front wheel
    Rear wheel
    Burna J likes this.
  2. Mprius
    Mprius Junior Member
    How is the ride with the new spring?
  3. Burna J
    1,068
    3,337
    53
    Long Beach, CA.
    Looks great... (y)
  4. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Looking Good!!! Make sure you get an alignment after the springs settle :cool:
  5. teckit604
    2013 Prius v wagon
    ride a bit stiffer, but still comfy.
  6. teckit604
    2013 Prius v wagon
    alignment was done right after the installation, but gonna recheck it later when i have time.
  7. h-dogg
    h-dogg Junior Member
    44
    South Bay
    cool, where did you pick up eibach springs from? i want to lower my wife's prius v3. i thought tanabe was the only company selling springs. i didn't know they carry them for the prius v. 1.5" drop is good.
  8. Mprius
    I installed the tanabe spring it was about 1.2 to 1.5" drop after the spring settle. The ride was just slightly stiffer than original which I prefer when baby asleep.
  9. GloryThief
    GloryThief Junior Member
    59
    The Westside
    2013 Prius v wagon
  10. BuckyB
    BuckyB Junior Member
    48
    Chatsworth, Ca
    2013 Prius v wagon
    Is this primarily for esthetic reasons or is there some other benefit?
  11. xliderider
    xliderider Senior Member
    8,130
    3,268
    Honolulu, HI
    Mostly aesthetic, especially with larger rims and low profile tires, the gap is accentuated. Makes an unlowered car look like it's on tip toes.
    Improves handling by lowering the vehicles' center of gravity and firms up the ride.
    SCH-I535
  12. h-dogg
    44
    South Bay
    Is the eibach direct install without modifications? I purchased the h&r ones from tire rack and my installer says these are wrong for the front springs. The h&r site doesn't list the v wagon model just the normal Prius...
  13. teckit604
    2013 Prius v wagon
    You have the normal prius springs, h&r doesn't make spring for the v. Cut the front spring about half a coil at the bottom, it will fit, that what I did to my Eibach.
    iPhone ?
  14. h-dogg
    44
    South Bay
    oh darnit..that's a bummer
  15. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I just had Tanabe NF 210 lowering springs installed last week. They are 5% stiffer and 1.5" lower and made specifically for the Prius v. At 50,000 miles I'll get Tokico adjustable shocks installed.
    The Tanabe springs seem to overpower my stock shocks even though they are listed as having only 5% more stiffness. It may be due to lowering the shock rod one inch. Either way the shocks don't seem capable of snubbing (dampening) the springs enough.
    Also I get rubbing in the fender well at or near full steering wheel lock. Irritating. I'll have to use a heat gun to move the offending area away from the tire. All these gremlins never happened when I put Eibach lowering springs on my tuned '95 Maxima. That's I lowered the v this time.
    SO... knowing all that I would have waited, installed the sway bars first and saved up for the complete spring/shock kit and paid the $500. labor cost only once. Aaarrrrggghh!
    #15 Eric "v", Nov 17, 2014
