Horn Upgrade --- DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evpv, Jan 2, 2011.
  1. Grren4ever
    Grren4ever Active Member
    347
    167
    Hi Guys,
    I just installed the horns today on my Prius. It was not difficult but I have a bad back so bending over the engine compartment was not fun:
    I had no idea the OEM horns were so small! Anyhow, on with the pictures. Because I am a worry-wort when it comes to the car, I questioned weather or not the new install would stand up to the elements. The install was not straight-forward because on the new horn, the connection clips did not face downwards. I had to remove a wire securing clip which attaches the wire to the bumper so that I would get more length to connect power to the horn.
    So as you can see, I had to break off the tab holding the wire in place so that more length could be used to connect to the horn's terminal. I also filled one of the connectors with silicone since it was facing upward and could collect water.
    Actually reading over some of the posts here, it looks like some have run into reliability issues with the connections. I will have to take off the emblem again in the future and start coating everything in silicone...lol.
  2. Seanzky
    Seanzky Member
    150
    28
    NY
    ^^ Couldn't you have just rotated the FIAMM horn so that the terminals would be reachable? Or move the ground wire to the terminal that's furthest from the car's harness?
    Coots likes this.
  3. Grren4ever
    347
    167
    I could rotate the horn but then it would face upwards and possibly collect water. Tried moving the ground wire around too. It would just be simpler if they made it so that the terminals on all these horns faced downwards!
  4. Seanzky
    Seanzky Member
    150
    28
    NY
    Gotcha. I just thought I'd ask because for me, the horn faces down and the harnesses still has a little bit of extra slack.
  5. pauerbach
    pauerbach Member
    101
    34
    How did all of you manage to remove the front emblem so easily? Two screws my behind! That thing wouldn't budge. Are there some additional clips holding it in place?
  6. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Do you have the collision avoidance?
  7. pauerbach
    pauerbach Member
    101
    34
    Nope. I do not.
  8. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    then there's just two clips left & right.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Give it a nice lil nudge from inside.
    VS980 4G ?
  10. evpv
    evpv Active Member
    690
    337
    West Coast
    2019 Prius Prime
    There are a few small plastic retainer tabs molded into the emblem. Once the two screws are removed it should push out fairly easily.
  11. StarCaller
    1,271
    723
    I started to remove the screws, then I figured it's not necessary.
  12. pauerbach
    pauerbach Member
    101
    34
    Yeah I see exactly the screws you're referring to. I took them both out. It still felt like it was held in by something else. I gave up. I didn't want to break some delicate plastic part by pushing too hard. I've done that enough times already...
  13. ibmoses
    ibmoses Junior Member
    109
    22
    Just did this Mod.
    Used a pair of snips to cut loose the retaining clip under the horn on driver side to provide some slack in wiring harness.
    Also on the right side of the hood latch is a bracket that is attached to the core support by two 10MM bolts. If you remove that it provides more room for the arm and also allows the use of a regular screwdriver in case you dont have a stubby or in my case could not find the stubby screwdriver:)
  14. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    The OEM connector fit right over the terminal on mine, the second terminal or ground I just jumped back to the mounting bolt before I installed them.
    with that jumper installed all I did was take the bolt out of the old one, put it in the new one and plug them back in.... done.
  15. thilt
    thilt Junior Member
    Friendswood, TX
    I'm in a 2014 Gen III (no V or C) with the DRCC. I had similar concerns but found the radar emitter is a separate box mounted behind the emblem. I was able to pull the emblem to do this without a problem.
  16. thilt
    thilt Junior Member
    Friendswood, TX
    Excellent instructions, though I deviated a bit.
    1. I used the El Grande horn set instead of the two separate ones.
    2. I found it easier to remove the entire mount and use the mounting brackets that came with the replacement horns (had more trouble trying to get the stock horn off of the bracket than removing the entire assembly from the mount). The screw into the horn just wouldn't budge.
    Once I got them out, my first thought was "man these stock things are dinky!"
    Thanks!
  17. varun singh
    varun singh Member
    113
    Wayzata
  18. StarCaller
    1,271
    723
    napa is exaggerating/
    this kind of horn doesn't get so loud/
    edit: I see that the measure at a distance of 4 inches..... just stupid/
  19. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    I have the FIAMM horns from NAPA, because at the time, Amazon had one of the horns marked as not being able to ship to Hawaii.
    They work well, and are pretty loud. They are going to be muted a little because they are mounted with the horn openings pointed downward, and the grills, etc will block some sound.
    I wouldn't put much stock into the difference in rated sound pressure levels claimed.
  20. varun singh
    varun singh Member
    113
    Wayzata
    Thanks for reply back, are these any better than the stock ones, any significant difference over the stock ones.
    With stock ones, nobody seems to taking me seriously though :rolleyes:.
    I am going to have some one install them for me, guessing when I get work done my front bumper, they might be able to swap these out :)
