Is this normal?
Discussion in 'Gen 2 Prius Main Forum' started by brin wood, Apr 22, 2014.
  1. brin wood
    brin wood Member
    100
    upstate NY
    Everytime I start my 06, I only move 5 to 10 feet and the engine starts up. I have no accessories on, and feather the gas pedal. The status shows at least 5 or more bars. I thought electric would propel me some distance at first.......but it doesn't.
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    perfectly normal
    depends on how much the battery is charged up
  3. bisco
    51,843
    actually, if the ice is fully warm, you should be able to go for a ways before it starts. as desmond says, the more battery, the more distance. you could have a bad hybrid or 12v battery. how are your mpg's?
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    No, this is completely normal. The Gen II is designed to start the ICE after 7 seconds. It will do this every time you start it no matter what the engine temp is. If the engine is at an acceptable operating temp, it will shut it down and go into S4 (full hybrid mode) in 7 seconds. There is absolutely nothing wrong with your car.
  5. cyberpriusII
    1,155
    1,763
    Mars Hotel
  6. bisco
    51,843
    okay, i misinterpreted 'start my car'. desmondlee and usnavystgc are correct. my comments are for post warm up. but if you have had the car for awhile and the behavior has changed, let us know.
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    I love it when people say that (because it happens so seldom). :)
