Prius topped off gas by the gas attendant...
Discussion in 'Gen 3 Prius Main Forum' started by Roger T, Apr 26, 2014.
  1. Roger T
    Roger T Member
    198
    48
    MA
    Two months ago I went to a full service shell station to refuel my Prius. The gas attendant was a teenage boy. When he was pumping gas, I remember he continued to add gas into my car after the FIRST CLICK. I heard at least 4 clicks after the first click.
    I was looking at the fuel reading all the time. I remember the first click happened at $26. He ended up at $30. The gas price was $3.89 per gallon... So I think he pumped one more gallon into my car.
    Any chance it is gonna ruin my fuel evaporation system? Or other damages? I remember I heard some gas splashing when i accelerated the car. The splashing sound disappeared after a trip for like 10 miles.
    So far I have got no error message on my dashboard yet.
  2. frodoz737
    frodoz737 Top Wrench
    4,646
    2,486
    33
    Been doing that way since new without issue.
    privilege and PriusGuy32 like this.
  3. bisco
    51,517
    no prolemo. no need to shut off at the first click, you just don't want to top it all the way up to the top of the filler neck. even then, damage is unusual.
  4. Roger T
    Roger T Member
    198
    48
    MA
    I have been reading threads about the harm of topping off gas on Prius... Of course my situation is not like faulty gas filler and gas overflow from the tank... But seems a bad idea to top off the gas.
    Gen III Gas Top Off, is it ok now?
    Is topping off the fuel tank bad for your Prius?
    I did not check the tank after that occasion. Do you think 1 gallon more gas into the tank after first click will fill up to the top of the filler neck?
  5. frodoz737
    4,646
    2,486
    33
    You asked and the answer is you will not break anything on your GEN III. Your car, do what makes you feel good. ;)
    mtbiker53 likes this.
  6. Roger T
    Roger T Member
    198
    48
    MA
    Great to hear that. :)
    I am not that worried... there is actually a related thread i posted. I suspect the overfill leads to the gas spill on the tank hole after I closed the cap, possibly from thermal expansion or sth.
    It happened on March 1. It has been really cold here tho... in Mass.
    Dirty stain inside gas tank door
  7. frodoz737
    4,646
    2,486
    33
    If that is your concern, then "top it off" right before your commute. This really is a non-issue though.
  8. Roger T
    Roger T Member
    198
    48
    MA
    Good idea. :)
  9. frodoz737
    4,646
    2,486
    33
    As to dirt and fuel residue behind the filler door area...normal. Just wipe it out when it bothers you.
  10. Roger T
    Roger T Member
    198
    48
    MA
    Great to hear that. I am new to cars... ;)
  11. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    No way to really answer that because you don't know at what level the first click actually occurred.
    IF the nozzle is shoved all the way in.......as it should be......then sometimes the first click-off will be triggered by gas splashing around in the tank. Going to the second click while keeping the nozzle tucked in is almost never a bad idea.
    More than that and all bets are off; same with not putting the nozzle all the way in.
  12. Mendel Leisk
    40,961
    I stop pumping the first time the pump shuts off. Not saying the rest of the world needs to do it, but it works for me. Reasons:
    1. Gets me out of there and the next customer to the pump sooner.
    2. Simple, works, is relatively consistent.
    3. Avoids possible spill, and/or possible screwing up of evaporative control system.
    I also avoid full-service pumps like the plague. Guess that rules out moving to Oregon...
  13. bisco
    51,517
    they have the plague?:eek:
    cwerdna and Nora like this.
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    After the 1st click you can still put in 2 more gallons, at least I can in our 2010 Prius. It
    is kind of nice to get an extra 100 miles of range.
    compac likes this.
  15. Grren4ever
    Grren4ever Active Member
    347
    167
    I kept topping off the fuel after the first click of my previous car. It ruined the EVAP system which caused a contant gasoline smell from the exterior of the car, a check engine light to come on (code P0440) and my technician suspected it flooded and ruined the canister filter. At the same time, my mileage took a really big hit from this since I believe the EVAP system was venting gas to the exterior environment.
    Don't do it! So you managed to squeeze a few more drops of gas at a lower cost from the pump..but you might potentially open a Pandora's box and cause a whole new slew of problems to pop up.
    I sold my previous car because of this problem, plus that fact that it needed about $4000 worth of other work (including a hit and run by a kid) to get it back to good working condition.
  16. Roger T
    Roger T Member
    198
    48
    MA
    Thanks for your story. I will stop after the first click from now on... Hopefully the one-time topping won't hurt a lot.
  17. bisco
    51,517
    and avoid full service like the plague!:p
  18. Mendel Leisk
    40,961
    Might as well have, I put those guys in the same league as Minute Lube and the like.
    My wife and I were across the street (thankfully) from a full service Esso. Full service is mandated in our municipality, I've never filled up there, hang on, maybe once. Thankfully we're near two neighbouring municipalities without such regulation. Anyway:
    The station attendant had apparently locked the pump on. You guessed it: the tank had filled, auto-shut-off had failed, and the gas was just agushing. At least 30 seconds, more like a minute, elapsed before someone finally strolled out of the gas station, did a VERY comical double-take, and started racing for the pump.
    No explosion, all good. Apart from liters and liters of gas down the storm drains.
  19. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    I always pump the gas and I quit on the second click, I never try to round up to the next dollar. It's pretty consistent and going more than that can damage EVAP stuff.
    WilDavis and CaliforniaBear like this.
  20. bisco
    51,517
    i used to round up to the dollar, now it's 10 cents.:cool:
