dry it out
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ispud, Apr 28, 2014.
  1. ispud
    ispud New Member
    Boise, Idaho
    When the weather is rainy I like to leave my doors open so things can dry out in my garage. When I do this the dash shows the doors as open. I worry about running down the battery if I do this, so I don't. Any ideas about how to turn this off? Also when I open the rear hatch a light goes on there and it has no switch - I would like to be able to turn this off also. Silly I know, but.....
  2. Mendel Leisk
    40,958
    Not so silly. Our regular prius hatch light has a switch, integrated into the light bezel. Opening either front door also turns on a light in the door, and little blue light in the door sill chrome piece. And lights in the foot wells. At least opening rear doors (apparently) turns no lights on. Oh, except the roof light (aka dome light), at least unless you switch it fully off.
    I've got all lights with switches on ours off. For ones without switches you could opt to pull the light out and disconnect the lead.
  3. bisco
    51,516
    or put a quick disconnect on the battery or a trickle charger.
  4. mister.e
    mister.e Junior Member
    Why not roll the windows down?
    Nexus 5 ?
  5. ispud
    ispud New Member
    Boise, Idaho
    trying to dry the door jams/sills/inner door edges.
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Those areas are not sealed.
    If the water can get in, so can the AIR.
    A quick wipe with a rag would be much simpler.......if you MUST obsess about it.
    Except for a 1969 VW van, I don't remember EVER seeing a car that had significant rust on the door jams.
    And installing an LED bulb for the hatch/trunk should solve that problem.
    Even the weak little battery in a Prius should be able to keep one LED running for weeks.
  7. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Hm. The c automatically shuts off the headlights and interior lights after 20 minutes. I wouldn't be surprised if this applies to the dash indicators as well.
  8. ispud
    ispud New Member
    Boise, Idaho
    I turned them on and left for 20 minutes - when I came back they were off - soooooo...that works!
    Thanks
