New ICE & traction battery for a 2005 with over 200K miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by devprius, Apr 30, 2014.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Long story short version is that the ICE in the 2005 Prius that my son owns has seized up due to an oil-leak/consumption issue that resulted in no oil in the engine and the resulting seizing of the ICE. A local hybrid specialty shop is quoting $2400 to replace the ICE (replacement ICE has 88K miles on it). They're also concerned that the traction battery might need replacement because it was drained down pretty low when the ICE seized, but won't know until they replace the ICE. It's the original traction battery that came with the car, so it is a bit long in the tooth. The quoted price for the traction battery replacement is $3200 which is supposed to be a new battery direct from Toyota and not a rebuilt one. I asked the shop owner about using a rebuilt one and he said that the supply of low-mile high-quality traction batteries has gotten pretty slim as the Gen IIs have gotten longer in the tooth.
    A used 2005 with about 187K miles on it is going for about 6 grand around here. And that's the cheapest I could find. Price goes up as mileage goes down, of course. Average price is about $7500 to $8000.
    The car is in otherwise good shape. No major dents or dings, no paint peeling problems, interior is still in decent shape, never been in a major accident or flood. I'm the actual original owner, so I know the history of the car. My gut feeling says to go ahead and at least replace the gas engine. Even if we have to replace the traction battery, it still seems like it's worth doing since it'll still be at least a grand cheaper than buying an equivalent used car with an unknown history, and I'll have a 12 months/12,000 mile warranty on the new ICE and traction battery.
  2. Former Member 68813
    3,524
    983
    US
    yep, it's not easy teaching kids to check oil.
  3. JC91006
    JC91006 Senior Member
    16,738
    8,550
    There are 2 specialty shops in your area. Art's and Luscious garage. I believe Luscious garage will be a cheaper option.
    I don't believe it's worth while to fix a car with that many miles on it. It would be different if you did all the work yourself, but if you have to pay someone, I would not do it. There are so many unknown's that can happen to a car with close to 200k miles. It's already at it's designed end of life.
    If the car is worth $6000 running, it might be worth $3000 not running. Instead of putting in a possible $2400 for an ICE and $2500 for a Battery (which you probably need both). You should sell the car for $3000-$4000 and add the $5000 to get an other lower mileage car. The out of pocket expense will be the same $5000 but by selling the car now, you will have $8000-$9000 to spend on a lower mileage car. Hope that makes sense.....
  4. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Judging from the original post and the shop's positions, I suspect that this car may be at Luscious Garage.
    As the other poster mentioned, I would be hesitant to dump this much money into a car of this age due to the inherent risk factor of other components approaching the end of their lifespan.
  5. Patrick Wong
    18,200
    6,500
    The OP has to decide whether his son can learn the concept of periodically checking engine oil level and also consider what are the alternatives to repairing the Prius, and what a suitable replacement vehicle would cost.
    I'd be inclined to replace the engine. Then, if the battery needs to be replaced, buy a used 3G battery and move the modules into the 2G battery case. I recently saw a 3G battery on eBay for <$1K including shipping.
  6. RexLex
    RexLex New Member
    Salem, Oregon
    I think I'd just take the repair money and buy a different car. Sell that one to salvage to help fund it.
  7. devprius
    devprius /dev/geek
    979
    291
    He's been made very painfully aware at how expensive a mistake this was on his part. He had been told repeatedly that he had to keep an eye on the oil level to the point of being told to check it every other fill-up. The fact that the low oil pressure light would come on when he went around corners should've been a big clue, but he ignored that and now has to pay the price.
  8. devprius
    devprius /dev/geek
    979
    291
    It is indeed at Luscious right now.
    I understand why a lot of people are advocating ditching the car and buying something with lower miles. And I agree with it to a certain degree. But I have no guarantee that if I buy a lower-mileage car I won't be facing the same problem down the line. I also won't know the complete history of the car. CarFax may not have all of the history. At least I know how well the car has been cared for and performed over the last 9.5 years. I know that some potentially expensive stuff, like the catalytic converter, were done at 140K miles under warranty. Or that the front brakes were finally touched at 140K. There's also the matter of whether I really could get $3000 for a Prius with a dead engine and a suspect traction battery.
    It seems to me that the parts you are most likely to have to replace on a car this old is primarily going to be the traction battery and ICE. Which are the most expensive. Everything else should be easy to do and not nearly as much money. Once I've replaced the very expensive bits with much lower mileage versions (or 0 miles in the case of the traction battery), it would seem like I'm getting a huge extension on the life of the car. Personally I'm hoping that it's just the ICE that needs replacing and the traction battery is fine. Up until this point there's been no indication of traction battery problems. At least with the ICE we knew there was an issue that had to be kept an eye on (and clearly wasn't).
    I've always been an advocate of keeping a car running as long as possible/practical. It's cheaper to repair a car that has been running well than to have to buy something new (or used). Obviously there's a point where the pain of fixing it is more than the pain of having to replace it. Figuring out what that pain point is the difficult part, but I don't think I'm quite there yet.
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I agree devprius. I think it's worth getting the low mileage engine dropped in there. Chances are the tractio0n battery will be fine once it charged up again.
    BTW. Just how low did it get discharged. Was it showing zero "bars" on the energy monitor?
  10. devprius
    devprius /dev/geek
    979
    291
    I'm not sure I agree witk you about not wanting to repair a car with 200K miles on it. Had I followed that advice last year, I'd be stuck paying for a new car for the next 5 years. Our minivan ended up needing about $4500 worth of work. Some of it was regular maintenance that needed to be done (new timing belt and water pump, regular oil & filter change, front brake service, transmission service, etc) and some of it was age-related stuff that finally needed fixing (new battery & cables, rear-brakes for the first time ever, fix leak in A/C including replacing various lines, O2 sensors). $4500 is about 6 to 8 month's worth of car payments (depending upon replacement car selected). The repairs have lasted for 16 months now. I'm ahead of the game. 200K is a lot of miles for a car, yes, but I no longer think it's towards the end of the life for a car. I think they can easily go another 100K miles with proper maintenance.
  11. devprius
    devprius /dev/geek
    979
    291
    Prior to getting loaded on to the flatbed it was at 1 bar on the MFD. The tow-truck driver ended up driving it on to the flatbed, so he may have drained it further. I wasn't at home to supervise. Had I been there, I would've made him use the winch instead. In the past when I've run out of gas in the car, the car was really good at preventing me from fully draining the battery. In this case, the car may have been constantly trying to spin the engine and failing to start, so it may have really drained it.
  12. uart
    uart Senior Member
    4,220
    1,209
    Australia
    One bar on the MFD shouldn't kill it. Some people here have reported running their battery down to 1 bar just driving mountain passes. I think one bar is still about 40% to 44% charge. Hopefully driving it onto the flatbed didn't discharge it much further.
    It is a problem though, the fact that you can keep driving until the main battery is dead when the engine loses power. Do you know if Luscious has the ability to recharge a traction battery?
  13. devprius
    devprius /dev/geek
    979
    291
    Luscious has an off-board traction battery charger they can use. They were going to replace the ICE first and then see where things stand. Not much point in charging the traction battery up if the ICE is still dead.
    When I ran out of gas and was just running on the battery, the car would go slower and slower as the battery bars counted down 1 by 1. By the time I hit 1 bar, I was barely crawling along, just enough power to pull off safely to the side and wait for triple-A to bring me some gas. It would not let me drain the battery any further. At least not actively. Leaving the car in IG-ON would try to make it periodically start the car which could further drain the battery, but I believe at that point the user is supposed to be smart enough to just turn the car off and wait for help. Kind of like in a regular car where when the car won't start, you have to be smart enough to stop trying otherwise you'll drain the 12V battery.
  14. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah but when fitting a new engine sometimes it takes a few tries to get everything right before it starts. You wouldn't want to strain the battery any further doing this. If it were me I think I'd prefer them to at least give it a partial charge while they're doing the engine.
  15. JC91006
    16,738
    8,550
    There are some really expensive components on the car that can fail around the age and mileage of your car. Even after the ICE replacement, you are going to need for sure need a HV battery in the short term (just because you have an original 2005). After that, it's a roll of the dice to determine if your transaxle and inverter holds up. Both of those items, if Luscious does it, will be $2500 jobs. Then you have to look at the condition of your shocks/struts, once again if you let Luscious do the work, it'll be 4 digits again. AC systems, MFD displays, etc. All those will have 200k miles of use and coming close to the 10 year mark.
    I guess if you are comfortable with putting a few thousand dollars aside for future repairs, it would be ok. It just would be a risk if you spend the money now ($5000 for battery and ice) and another failure comes shortly after and require more money, then you decide it's not worth it. I guess once you spend the money now, it would be hard to let go once other repairs come up.
    If you were to get all the parts yourself, it would be less expensive just to pay the labor. Luscious gets the parts for you and has a pretty good used markup on the parts. Engines online cost $300-$500. But Luscious do guarantee the stuff they put in, so it would come down to how much risk you are willing to take.
  16. devprius
    devprius /dev/geek
    979
    291
    They're a pretty highly rated hybrid shop and know what they're doing, including engine replacements. I'm sure they'll take every precaution needed.
  17. devprius
    devprius /dev/geek
    979
    291
    Those are all good points and something for us to keep in mind down the line. Right now I'm willing to risk a $2400 engine replacement, and possibly a replacement traction battery. If other things start failing after that, then we'll consider selling the car (with a brand-new traction battery and nearly new ICE!) and taking that money and putting it towards something else. If nothing else, it'll be a good lesson for my son as to why proper maintenance is important "See, you'd have an extra $2400 for these other repairs if you had remembered to check the oil!"
    CatsAreGods likes this.
  18. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Well if the consumer reports survey/statistics are to be believed then only about 2% of 2005 batteries have failed to date. I cannot see how you can extrapolate that the HV battery is certain to fail very soon from that data.
    Too many doom and gloom merchants here. It may keep going for another 100k miles.
  19. JC91006
    16,738
    8,550
    Cases like this, I tend not to give the best outcome scenario, but rather give closer to the worst outcome scenario to prepare them. Then it won't be quite a surprise if it does fail. I don't like to say "your car will be fine for possibly another 100k" when it can fail in the next 1k. I'm a doom and gloom guy :)
  20. JC91006
    16,738
    8,550
    I also don't think the percentage of failed batteries to be at 2%. The marketplace is full of advertisements for battery rebuilding. It's everywhere. If the failure rate is truly 2%, there wouldn't be enough business for all the marketplace to be advertising their services so aggressively.
