How many ounces of oil does your Prius use between oil changes?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ski.dive, May 4, 2014.
  1. AzWxGuy
    AzWxGuy Weather Guy
    1,028
    517
    Tucson, AZ
    2021 Prius
    I switched from a synthetic to a high mileage blend at 130K due to increased oil consumption. It was using about a quart at the time and that decreased over the next 3-4 changes to maybe 20-24 ounces between changes. Now that the engine is over 170K the consumption is back over a quart, maybe 36-40 ounces. It's hard to estimate what is drained out when placed in an empty gallon milk jug. The ICE has almost all highway miles on it, so the wear and oil usage are to be expected. I will get a better idea in a week when I change oil again. That happens about every two months with the miles I drive.
  2. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I really don't like that method of monitoring oil consumption. What's wrong with keeping it topped off and just noting how much oil you have to add. It's more accurate and has the added benefit that you actually keep the oil topped off.
    So many people with oil consumption problems and apparently some kind of aversion to topping off. :confused:
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,028
    517
    Tucson, AZ
    2021 Prius
    Oh, I do top off. Sorry, didn't include that info. I don't let the level get below the halfway point on the dip stick, unless it is within a couple days of changing time. Up to this point I have managed to only need the remaining 1/2 quart from the 3 1/2 quart fill, but this next time around and subsequent I will most likely be buying 5 quarts of oil. Hey, maybe there is some savings in that if I get that 5 quart single container.
  4. uart
    uart Senior Member
    4,220
    1,209
    Australia
    (y) Just keep a note of how much top off oil you need per oil change interval and you keep a pretty accurate track of oil consumption.
    Yeah it's a big saving where I live. I mean literally about two thirds the price when buying 5L instead of individual liter bottles. Sometimes even cheaper as 5L bottles go on sale much more often too. :)
    AzWxGuy likes this.
  5. theshark
    theshark Member
    164
    Martinsburg, WV
    what's funny: Toyota says 1 qt in 800 is miles is acceptable. I say: Bull hockey!!
  6. ski.dive
    ski.dive Active Member
    957
    241
    Hutchinson Island,FL. Mt. Snow,VT
    ADVANCED AUTO PARTS, always has great deals on oil
  7. Mendel Leisk
    40,484
    Getting into pricing: $5.65 Canadian per liter bottle of Toyota 0W20, at the dealership parts department.
  8. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    My 2005 with 130k isn't using yet. I've always let the dealer change it and they always overfill just a little. Plus you get free popcorn!
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,028
    517
    Tucson, AZ
    2021 Prius
    The results of the oil change were 4 quarts 12 ounces added and I eyeballed about 2 quarts 4 ounces drained, so in 4804 miles it used 2 quarts 8 ounces. And that is all interstate travel miles and the odometer now at 175K.
  10. Mendel Leisk
    40,484
    If that's all you drained you're running the car's oil down to damaging levels. If this is with the aim to determine oil loss, I'd say just keep topping up periodically, to bring it back to the top dimple on dipstick, and track how much you needed to add, how much of a bottle, or multiple bottles.
  11. AzWxGuy
    AzWxGuy Weather Guy
    1,028
    517
    Tucson, AZ
    2021 Prius
    Yes, I did run it a bit low that time. Eighth inch above the lower dimple on the stick. I usually refill to an eighth inch below the top dimple when it gets to the halfway point, which I will continue to do.
