Adding 1000w inverter question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JC91006, May 11, 2014.
  1. JC91006
    JC91006 Senior Member
    16,651
    8,501
    Hello All
    I'm in the process of adding the necessary wiring to add a 1000w inverter to my Prius. I read many people are just connecting the 1000w inverter directly onto the Prius 12v via battery jumper clamp type of connection. This seems to work fine.
    However I'm looking at "How to" write ups and almost everyone is adding an 80 amp fuse in their wiring. Is this addition fuse necessary or just a precaution? Has anyone ever blown this 80 amp fuse with normal usage?
    Thanks for your feedbacks.
  2. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I have a 80a fuse, and a 4000 watt inverter hooked up in mine. Direct to the 12v battery.
  3. JC91006
    16,651
    8,501
    That's a big waste of a 4000w inverter. From all the reading I've done, a direct hookup to the 12v shouldn't benefit from anything over 1000w.
    Minima Domum likes this.
  4. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    It's a 4000w peak, 2000w continuous inverter. I've had 2k run continuous with no issues. Fuse isn't necessary as the inverter has a fail safe built in.
  5. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I've also used it to run the blower on my furnace during a power outage for 14 hours
  6. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    The fuse is to protect you if the battery gets shorted out. It will gladly release all of it's energy in a very short time...think arc welding.
  7. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Hence the built in 80a fuse in the inverter.
  8. JPTuck
    JPTuck Member
    110
    29
    South Deerfield, Mass
    Just curious-is the 12v battery charged from the engine when running or it it charged from the traction battery?
  9. CatsAreGods
    CatsAreGods Junior Member
    46
    The 12V battery is charged directly from the traction battery, which is charged by the ICE.
    Nexus 4 ?
  10. JPTuck
    JPTuck Member
    110
    29
    Nice to know - thx.
  11. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    The built-in fuse won't help any if the positive cable to the inverter gets rubbed through or damaged and grounds out before it gets to the inverter ;) hence the fuse as close to the battery as possible.
  12. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Not needed when the cable is 6inches long and touches nothing.
    (However mine is fused 80a)
    Thanks
  13. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Good point. I had no way of knowing that lol. Slightly off topic but not much: I found an awesome board that skips the 12v system and concerts 190v DC to 240v ac. Problem is I have no info on parts or availability. It's by Martek Power[​IMG]
    Minima Domum and WNY-HYBRID like this.
  14. CatsAreGods
    46
    Call your local dealer:
    Martek
    Nexus 4 ?
  15. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Local being 4+ hours away lol. Hey it would still be quick shipping :p
  16. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    If you call let us know how $$
  17. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Called and left a message. Now the fun part...waiting lol
  18. JC91006
    16,651
    8,501
    Ok, back to the original topic. I won't allow this thread to be hi jacked :)
  19. drysider
    823
    335
    Liberty Lake WA
    The internal fuse will do nothing to protect from a short-circuit in the upstream wiring. It is there to protect the internal electronics of the inverter. Always have a fuse as close to the battery as possible...right off of the terminal is best.
    Minima Domum and edthefox5 like this.
  20. JC91006
    16,651
    8,501
    There are several types of 80amp fuses, are there any specific kinds I should use? Most I see use a type called ANL fuse. I see other kinds out there for audio purposes, not sure if it's any different.
