Handling Upgrade Suggestions for 2007 Touring
Discussion in 'Gen 2 Prius Accessories & Modifications' started by andrewsilver, May 12, 2014.
  1. andrewsilver
    andrewsilver Enthusiast
    33
    Frisco, TX
    Looking for advice on improving the cornering on my 2007 Prius Touring.
    A few years ago I installed a BT Tech Strut Tower Brace and BT Tech Chassis Stiffening Plate. I like them but I'd like to further improve the cornering and reduce body roll a bit more. I'd prefer not to lower the car - just stiffen it.
    The items I've been considering are:
    1. Tanabe Sustec front under brace ~$125
    2. Tom's Lower Body Brace ~$600
    3. Tom's Front Suspension Brace ~$325
    4. Tom's Floor Strengthening Brace ~$350
    Thoughts/comments/suggestions appreciated.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    None of the above.
    Just put a Toyota Matrix / Vibe rear sway bar on. What a difference in the feel of the car. It just feels more solid on the road. Easy mod too. You can get the sway bar for $35 from the junk yard.
    Eclipse1701d likes this.
  3. andrewsilver
    33
    Frisco, TX
    That's an interesting idea. What year Matrix/Vibe rear sway bars fit? Are there any writeups on priuschat for how to do install it? thanks.
  4. JC91006
    JC91006 Senior Member
    16,827
    8,600
    This thing??
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I used the progressive bar from th motorsports on the rear which takes less than 1/2 hour to install, and a corolla front bar from the junk yard from I think its '03 - '08. that's a bit harder job but all those braces you mentioned will do nothing for body roll. though they will reduce body flex.
    I felt the body roll is excessive with oe sway bars; after replacing both bars it corners very flat. with just the rear bar it was much better, but it felt to me that the rear end wanted to kick out when you pushed it. very well balanced with both bars. I also run 205 tires, 215's would be even better.
    Daves09prius and caymandiver75 like this.
  6. andrewsilver
    33
    Frisco, TX
    Where can I get the THM rear bar? I can't find it online. Thanks!
  7. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
  8. andrewsilver
    33
    Frisco, TX
    Ok I just ordered the Progress Technology 62.2150 Rear Anti-Roll Bar from autoplicity. Thanks!
    Next I'll want to do the Corolla front bar - I'll have to start looking for one at the junk yard or ebay. Anyone have instructions how to install it?
  9. 69shovlhed
    2,170
    752
    Delaware
    yes, the progress bar is what you want (I need to fix my signature)
    there are install instructions in a thread about sway bars; not sure which one. you'll have to find it. biggest hassle is most folks had to lower the engine sub-frame at the rear to get the new bar in. also make sure your corolla bar comes with bushings and brackets for the frame cause the old bushings won't fit.
  10. andrewsilver
    33
    Frisco, TX
    I ordered the Progress Bar and installed it. Pretty easy - 2 bolts, 15 minutes. I did notice an improvement in cornering. I still want to do more, so probably need to learn more about the Corolla front sway bar and how to install it. Has anyone done a writeup with pictures? Thanks.
    Daves09prius likes this.
  11. 69shovlhed
    2,170
    752
    Delaware
    I don't remember any pics... its not a hard job except for dropping the subframe down a little. there is a thread on sway bars which several people wrote about their sway bar install. search sway bar and you'll find it.
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I took a few pictures: Modding My 2008 Touring...."JustDidIt" | Page 7 | PriusChat
    Some of the in-line links are broken but the attachments still work.
  13. a_gray_prius
    2,927
    783
    IL
    I highly recommend stickier tires. You do lose some MPG though.
  14. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    I highly recommend Michelin Defenders over Energy Savers or Ecopias, they're just a better performing tire at slight MPG cost (still LRR).
  15. andrewsilver
    33
    Frisco, TX
    Thanks. What size Michelin Defenders are you using? They don't appear to come in the stock size for a Prius Touring 195/55R16.
    Btw, I've been driving with my new Progress Technology 62.2150 Rear Anti-Roll Bar and the difference is noticeable. Thanks for the advice.
  16. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    Whoops. I didn't realize you had a Touring model and that Defenders didn't come in the stock size. Hopefully someone can chime in regarding "alternative" sizes for the Touring (I can only find alternate size recommendations for non-touring) and compare it to the available sizes of Michelin Defender (seems to be: Michelin Defender ).
  17. 69shovlhed
    2,170
    752
    Delaware
    205's fit the 15" wheels good. might be a 205/50 or 55 would work on a touring. for some very stupid reason Toyota didn't sell the touring in the DC area. I almost never see one.
