2010 Prius loses inverter fluid in 24hrs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Slysmile, May 12, 2014.
  1. Slysmile
    Slysmile New Member
    My Prius gave me the triangle of death, though it's the yellow version, and check engine. When I did I found that the inverter fluid was gone, so I filled it back up. As it sat overnight it ran out again. It's going to the shop today. Is there anything I need to be on the lookout for? Never needed to have it taken in before. Thanks
  2. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Welcome! as for where you need to look... you havent seen any wet spot under your vehicle? not a stupid question
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    Also welcome to PC...has your Prius had the recall done for the inverter overheating issue? How many miles are on your car. Are you the original owner?
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I'm going with damage to invertor radiator. Needs to be replaced.
    The Critic likes this.
